Vag Com Fault Codes
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
wrightbr
Vag Com Fault Codes
Post by wrightbr » Tue Feb 07, 2006 9:49 am
Guys,
I ran vag com on my car the other day and done a search for fault codes and the following fault codes appeared
vag com alerts
DTC REsults
Address 01: Engine
17865 - Exhaust Gas Temp Sender 2 (G236): Open or short to Plus
P1457 - 35-00 - -
Address 55:Xenon Range
01538 - Motors for Headlight Reange Adjustment (V48) / V49
29-00 - Short to
I have searched the site but have not found the answers to the following questions. I am going to relace the gas temp sensor but does anybody know which side this refers to (near side or offside bank?)?
With the Xenon error code if the headlights are set up in the right position then I am assuming that this is not an issue? Is that correct?
Thanks,
Brad
KayGee
RE: Vag Com Fault Codes
Post by KayGee » Tue Feb 07, 2006 11:12 am
According to SS198, G236 is passenger side, assuming yours is a RHD version.
Re: Xenons they should be fine, other drivers will soon let you know if there is a problem with them. Mos garages have a quick check chart on the wall you can drive up to to verify.
wrightbr
Post by wrightbr » Tue Feb 07, 2006 2:24 pm
Key Gee,
Many thanks for the reply.
Yes it is a right hand drive model (UK car)so I guess this is the passenger side sensor. Has anybody replaced one of these before? Is it easy to access and is it likely to be hard to remove?
Brad
s4woody
Post by s4woody » Tue Feb 07, 2006 2:37 pm
ive done both of mine..the drivers side when the V (inlet manifold) was off and the other side when it was back on..the passenger side is the worst to do but it is dooable..where abouts are u located??anywhere near south london.. :redrs4:
GARTH ROAD MOT CENTRE LTD
020 83353032
wrightbr
Post by wrightbr » Tue Feb 07, 2006 3:19 pm
Thanks S4woody.
I am based in Maidstone in Kent so not far away.
I will probrably get a mechanic friend of mine to do it just wondered how much work was involved for him and if I could give him any pointers to make it easier?
Waiting on a price from Vagparts at the moment for the sensor.
What are the implications of this faulty sensor?
Thanks,
Brad
kevinw
Post by kevinw » Tue Feb 07, 2006 3:58 pm
Brad
I replaced my front near side Xenon sensor last week. Easy job, just take the wheel off and access is easy - got the part from Vag parts £25 instead of £55 from Audi. My Xenons now work again after being stuck on the minimum setting.
However - is yours the Xenon motor?
wrightbr
Post by wrightbr » Tue Feb 07, 2006 4:30 pm
Thanks Kevin.
Assume that it is the sensor as well but hard to find a answer for the code. Assume could be both sensors as DTC states (V48) and V49 which I assume is the code for the sensors ?
I will add these to my list for vagparts ;0)
Brad
s4woody
Post by s4woody » Tue Feb 07, 2006 6:08 pm
theres 2 10mm bolts 2 remove off the sheild then u can get 2 it..its tight but can be done..unplug it undo the sensor then refit new then fit back bolts then done..well it sounds easy but just fiddly.. :redrs4:
020 83353032
peterb
Post by peterb » Wed Feb 08, 2006 10:37 am
V48 and V49 are the range control motors, so the fault is either in one of the motors, or the wiring between J431 (the control unit) and the motor. When you first turn your headlights on you should find that the beams come up from the rest position, taking about a second - does this happen? Is it only one light which does this?
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
wrightbr
Post by wrightbr » Wed Feb 08, 2006 1:00 pm
Peter
Not sure I think that the lights rise slightly ( Iwill confirm tonight), and the offside seems slightly higher than the nearside (about 1/2 inch or so ). Where is the control unit located? If the beams are within the MOT settings is this anything to worry about, and if not within the settings then can they be set manually?
S4 Woody
Thanks for the info on the sensor removal.
Brad
wrightbr
Post by wrightbr » Wed Feb 08, 2006 1:09 pm
Also changed side light bulb on offside a month or so ago, is it possible there are any wires located nearby for the light motor that I could have knocked off?
DavidT
Post by DavidT » Wed Feb 08, 2006 1:12 pm
I'm reading this thread with interest as my headlights were pointing at the ground when I collected it the other week. I guess its a connection issue as the car was fine before that.
Sorry to hijack the thread.
s4woody
Post by s4woody » Wed Feb 08, 2006 1:13 pm
thats a possibility cos i did that when i changed my oem sidelight bulbs 4 led,s..i soon sussed it out and refitted the wire..and the led sidelight bulbs look like baby xenon lights..wicked.. :redrs4:
020 83353032
wrightbr
Post by wrightbr » Wed Feb 08, 2006 1:37 pm
S4Woody.
Interesting :D
can you remeber whereabouts the offending wire was?
Thanks,
Brad
kevinw
Post by kevinw » Wed Feb 08, 2006 4:20 pm
Davidt
I had the same problem and replaced the near side fron sensor (fault code 776). Lights now work fine.
regards
Return to “DTC / VCDS”
Users browsing this forum: Google Adsense [Bot] and 31 guests
