Coilovers
Re: Coilovers
Cool. I would tack the cylinder back together though. At several points around the circumference.
Re: Coilovers
Hard to say without seeing it up close. Solder won't do it IMO. MIG / TIG I think the best bet. It might not appreciate a bead all the way round so I'd probably tack it in 8 locations around the circumference.
Re: Coilovers
(TIG) Weld would be much more precise. To solder, you’d probably end up putting quite a bit more heat than you like in.
Re: Coilovers
Cheers guys. I’ll carry on with the reconditioning for now and leave that to the end.
Re: Coilovers
I don’t know if this is of any use to anyone but Auto doc have 40% off today.
As a result I’ve cancelled my B14 order and have now brought a set of B16 PSS9s as they’re delivered for £1250.
Re: Coilovers
Wow. That's a bargain! Nice one. You won't regret it, they are much better.
- anditsoundslikebells
Re: Coilovers
damn.... just had mine fitted. you did well!
mine have changed the car.
RS6 C5 Avant 2002 Daytona Grey
TTH 620 - Wagner IC - OC.T 200cell&downpipes - DW400 pump - 034 TCU chip - FIS - B16 PSS9 - 034 control arms - H&R ARB - OZ Superturismo
Re: Coilovers
The B14 were just getting pushed back each month so I’d been keeping an eye on Auto Docs prices.
Yes, I’m happy knowing it’s the same set up as previous as the ride was great.
Re: Coilovers
Finally, after what feels like an eternity, I have fitted the front Bilsteins. She now seat very clear of the arch to a point that I think I might lower her 10mm if she doesn’t settle down.
Still got the rears to fit but I’m in no hurry to do this and will enjoy having the car back on the road for a bit.
Re: Coilovers
Seems a bit high. I'm surprised you can go that high. I'm pretty sure mine is almost maxed out in height and it's nowhere near that high. Mine did settle slightly after a few weeks, I seem to remember. Though it was a long time ago and my memory's crap.
Are these PSS9 or PSS10?
Re: Coilovers
B16 PSS9.Shoppinit wrote: ↑Tue Jun 28, 2022 5:11 pmSeems a bit high. I'm surprised you can go that high. I'm pretty sure mine is almost maxed out in height and it's nowhere near that high. Mine did settle slightly after a few weeks, I seem to remember. Though it was a long time ago and my memory's crap.
Re: Coilovers
Is the engine still in the front?
Re: Coilovers
Yeah, it is a little high but pretty sure it'll settle down a bit.
Users browsing this forum: srichards and 108 guests
