Coilovers
Re: Coilovers
Post by Shoppinit » Wed Mar 02, 2022 9:12 am
Cool. I would tack the cylinder back together though. At several points around the circumference.
ChrisA
Re: Coilovers
Post by ChrisA » Wed Mar 02, 2022 9:49 am
What would you recommend? I was thinking that a wire brush and some soldering would do the job or do you think it would need a proper weld?
Re: Coilovers
Post by Shoppinit » Wed Mar 02, 2022 9:53 am
Hard to say without seeing it up close. Solder won't do it IMO. MIG / TIG I think the best bet. It might not appreciate a bead all the way round so I'd probably tack it in 8 locations around the circumference.
Mɐʇʇ
Re: Coilovers
Post by Mɐʇʇ » Wed Mar 02, 2022 9:54 am
(TIG) Weld would be much more precise. To solder, you’d probably end up putting quite a bit more heat than you like in.
ChrisA
Re: Coilovers
Post by ChrisA » Wed Mar 02, 2022 3:17 pm
Cheers guys. I’ll carry on with the reconditioning for now and leave that to the end. 👍
ChrisA
Re: Coilovers
Post by ChrisA » Mon Jun 20, 2022 7:56 am
I don’t know if this is of any use to anyone but Auto doc have 40% off today.
As a result I’ve cancelled my B14 order and have now brought a set of B16 PSS9s as they’re delivered for £1250. 👍
Re: Coilovers
Post by Shoppinit » Mon Jun 20, 2022 8:00 am
Wow. That's a bargain! Nice one. You won't regret it, they are much better.
anditsoundslikebells
Re: Coilovers
Post by anditsoundslikebells » Mon Jun 20, 2022 12:54 pm
damn.... just had mine fitted. you did well!
mine have changed the car.
RS6 C5 Avant 2002 Daytona Grey
TTH 620 - Wagner IC - OC.T 200cell&downpipes - DW400 pump - 034 TCU chip - FIS - B16 PSS9 - 034 control arms - H&R ARB - OZ Superturismo
ChrisA
Re: Coilovers
Post by ChrisA » Mon Jun 20, 2022 3:08 pm
The B14 were just getting pushed back each month so I’d been keeping an eye on Auto Docs prices.
Yes, I’m happy knowing it’s the same set up as previous as the ride was great. 👍
ChrisA
Re: Coilovers
Post by ChrisA » Tue Jun 28, 2022 5:08 pm
Finally, after what feels like an eternity, I have fitted the front Bilsteins. She now seat very clear of the arch to a point that I think I might lower her 10mm if she doesn’t settle down.
Still got the rears to fit but I’m in no hurry to do this and will enjoy having the car back on the road for a bit. 😎
Re: Coilovers
Post by Shoppinit » Tue Jun 28, 2022 5:11 pm
Seems a bit high. I'm surprised you can go that high. I'm pretty sure mine is almost maxed out in height and it's nowhere near that high. Mine did settle slightly after a few weeks, I seem to remember. Though it was a long time ago and my memory's crap.
Are these PSS9 or PSS10?
ChrisA
Re: Coilovers
Post by ChrisA » Tue Jun 28, 2022 5:41 pm
B16 PSS9. 👍
Re: Coilovers
Post by chunky79 » Wed Jun 29, 2022 7:15 pm
Is the engine still in the front?
ChrisA
Re: Coilovers
Post by ChrisA » Thu Jun 30, 2022 6:52 pm
🤣 I think so. I wasn’t expecting it to be that high as it’s probably only 10mm higher on the new coilovers compared to the old ones. I’m guessing the old top mounts had been compressed somewhat too?
Re: Coilovers
Post by chunky79 » Thu Jun 30, 2022 7:28 pm
Yeah, it is a little high but pretty sure it'll settle down a bit.
Users browsing this forum: Google [Bot], Shoppinit, srichards and 156 guests
