Fuse 29 interrupt switch
Lander91
Post by Lander91 » Mon Jan 17, 2022 10:11 pm
Quick hack share.
I drive my 6 only a few times a month and have noticed before that if I start it up after it's been sitting I get the top end rattle.
Pulling the #29 fuse, as outlined on this forum, and cranking it a couple of times for 7 or 8 seconds a time to get oil pressure up means a quiet start once the fuse is replaced.
It's a bit of a faff, so I decided to hook up a switched circuit for fuse 29.
Not the best looking end where the circuit plugs into the fuse location, but I works and is secure.
I hacked up a fuse to the solder the wires to it as using spade connectors was too loosey goosey.
Circuit has an inline fuse holder, then the switch is mounted in a hidden location.
Works a treat and means I can just get in the car and close the door, flick the switch go through the cranking process then hit the switch again for the proper start.
Anyway for reference if anyone wanted to try the same thing.
Re: Fuse 29 interrupt switch
Post by Shoppinit » Mon Jan 17, 2022 10:33 pm
That’s not a bad idea. Might do the same but without the spunk all over it.
Lander91
Post by Lander91 » Tue Jan 18, 2022 1:28 am
I can get a bit excited when it comes (pun?) to working on the 6.
mavada
Post by mavada » Mon Jan 24, 2022 11:54 am
Nice one, thats on my todo list shortly.👍
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Astrosquirrel
Post by Astrosquirrel » Mon Jan 24, 2022 5:20 pm
Awesome tip. Thanks! :)
mavada
Post by mavada » Sat Apr 30, 2022 8:53 pm
Yellow Koni's
Lander91
Post by Lander91 » Sat Apr 30, 2022 9:07 pm
ATC/ATO by the looks. I searched high and low here locally for a solution like that. May need 90deg spade connectors depending on the installed height. Amazon here I come, thanks Mav.
ChrisA
Post by ChrisA » Fri May 06, 2022 7:09 am
Can you report back which one you went for and if you’re happy with it as I think my RS is about to move into the weekend winter car rather than daily driver.
I’d be happy to put together an order to build several kits if there’s a demand? (However I dare say there’s others on the forum with better soldering skills than mine 😊)
Mɐʇʇ
Post by Mɐʇʇ » Fri May 06, 2022 7:17 pm
Couldn’t you just floor it so it goes into anti flood mode to prevent starting?
Post by Shoppinit » Fri May 06, 2022 7:21 pm
Doesn’t work on the RS6. Now *that’s* a good way to shear a cam lobe. :)
Mɐʇʇ
Post by Mɐʇʇ » Fri May 06, 2022 7:38 pm
I was hoping one of you would try it for me. :mrgreen:
Lander91
Post by Lander91 » Fri May 20, 2022 9:37 pm
Haven't pulled the trigger yet. I've got a few other projects on the go. But it'll be the ATO/ATC version.
Users browsing this forum: B_O_N_K, Cunningstunt and 118 guests
