On the road again...
mavada
Re: On the road again...
Post by mavada » Tue Sep 21, 2021 2:29 pm
I just noticed a puf of blue smoke after starting from cold.
Never seen this before.
Started twice from cold with 2 or so hours in between, just to set the 6 somewhere else.
Something to worry about?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Tue Sep 21, 2021 3:02 pm
You sure it's blue?
mavada
Post by mavada » Tue Sep 21, 2021 3:12 pm
Yes, definately;)
Noticed it flowing from the right side, dont know if it came from the left or both sides...
Yellow Koni's
Post by Shoppinit » Tue Sep 21, 2021 3:14 pm
Probably valve stem seals. What oil are you using?
Post by Shoppinit » Tue Sep 21, 2021 3:15 pm
Sometimes grey smoke looks like blue.
mavada
Post by mavada » Tue Sep 21, 2021 3:21 pm
Yeah, i will have someone look at the back when starting from cold.
Im using Motul 5w40 full synthetic.
Yellow Koni's
NC5RS6owner
Post by NC5RS6owner » Tue Sep 21, 2021 4:07 pm
Which is the best one to use ? If you are doing a oil change our is there a few out there
Post by Shoppinit » Tue Sep 21, 2021 4:31 pm
Any VW505.01 is fine.
Mɐʇʇ
Post by Mɐʇʇ » Tue Sep 21, 2021 9:02 pm
For the UK crew, I buy 20 litres at a time of this : https://www.opieoils.co.uk/p-60457-cast ... e-oil.aspx
Meets the spec for the RS and most other stuff too.
mavada
Post by mavada » Wed Sep 22, 2021 3:47 pm
No blue smoke today...
Yellow Koni's
mavada
Post by mavada » Thu Sep 23, 2021 8:42 am
Got a airbag light in the dash yesterday, for about 10 seconds after starting :audibash:
Yellow Koni's
Mɐʇʇ
Post by Mɐʇʇ » Thu Sep 23, 2021 8:45 am
It is always the last light to go out on mine.
It did have an airbag light on when I bought it - I think the PO had had the seats full back and full reclined for some shenanigans and it tweaked the connectors.
I just reset it via VCDS and all has been fine since.
Post by Shoppinit » Thu Sep 23, 2021 8:47 am
If the light went out on its own, I wouldn't worry too much about it. You could always scan for intermittent faults.
NC5RS6owner
Post by NC5RS6owner » Thu Sep 23, 2021 4:06 pm
Cheers for the reply
mavada
Post by mavada » Thu Sep 30, 2021 9:05 am
Got the tyrepressure warning light yesterday, dont have them:)
Looks like the 6 is periodically checking if all those warning light are working ok...
Yellow Koni's
Users browsing this forum: srichards and 70 guests
