On the road again...
Re: On the road again...
I just noticed a puf of blue smoke after starting from cold.
Never seen this before.
Started twice from cold with 2 or so hours in between, just to set the 6 somewhere else.
Something to worry about?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
You sure it's blue?
Yes, definately;)
Noticed it flowing from the right side, dont know if it came from the left or both sides...
Yellow Koni's
Yellow Koni's
Probably valve stem seals. What oil are you using?
Sometimes grey smoke looks like blue.
Yeah, i will have someone look at the back when starting from cold.
Im using Motul 5w40 full synthetic.
Yellow Koni's
Yellow Koni's
NC5RS6owner
- 1st Gear
Any VW505.01 is fine.
For the UK crew, I buy 20 litres at a time of this : https://www.opieoils.co.uk/p-60457-cast ... e-oil.aspx
Meets the spec for the RS and most other stuff too.
No blue smoke today...
Yellow Koni's
Yellow Koni's
Got a airbag light in the dash yesterday, for about 10 seconds after starting
Yellow Koni's
Yellow Koni's
It is always the last light to go out on mine.
It did have an airbag light on when I bought it - I think the PO had had the seats full back and full reclined for some shenanigans and it tweaked the connectors.
I just reset it via VCDS and all has been fine since.
If the light went out on its own, I wouldn't worry too much about it. You could always scan for intermittent faults.
NC5RS6owner
- 1st Gear
Got the tyrepressure warning light yesterday, dont have them:)
Looks like the 6 is periodically checking if all those warning light are working ok...
Yellow Koni's
Yellow Koni's
Users browsing this forum: Majestic-12 [Bot] and 161 guests
