On the road again...
mavada
Re: On the road again...
Post by mavada » Thu Jul 29, 2021 8:31 pm
I just noticed the rubber part in the top strut has kind of moved a bit outwards as can be seen in the pic.
Dont tell me the shock has to come out to re-align it? :sleeping_2:
I see when the old shock came out, the rubber part kind of is in the same position...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
mavada
Post by mavada » Wed Aug 04, 2021 9:40 am
Fronts done, love the noiseless and firm front.
Trying to get the rears done this week if all bolts and nuts are coming loose and are accessable...
Some say the rears are more easy, some say not.
Forgot to blow/suck out the oil from the cut DRC lines, they are still leaking on the driveway :bash:
Yellow Koni's
mavada
Post by mavada » Wed Aug 04, 2021 12:37 pm
@Ben:
Did you re-use suspension bolts and nuts for the rears?
Yellow Koni's
Post by Shoppinit » Wed Aug 04, 2021 1:03 pm
Yup. Pretty sure I did.
mavada
Post by mavada » Wed Aug 04, 2021 1:32 pm
:thumbs:
Yellow Koni's
Post by chunky79 » Thu Aug 05, 2021 8:49 am
Ichbinasshole, if you wanna send me a pm making out you're sooooo much better than everyone AGAIN, have the balls to let me send a reply TO YOU, you PUSSY.
Mɐʇʇ
Post by Mɐʇʇ » Thu Aug 05, 2021 9:20 am
I’m still simultaneously insulted and relieved I wasn’t the recipient
Maybe he just doesn’t like Porsches?
Post by Shoppinit » Thu Aug 05, 2021 9:21 am
I’ll send you some abusive hate mail if you want, Matt. Would hate for you to feel left out.
steve2003rs6
Post by steve2003rs6 » Thu Aug 05, 2021 9:30 am
Don’t forget my hate mail as well Ben.
Hate to be left out.
But it’s not pussy by the way. It’s poosey !
Foxmeister
Post by Foxmeister » Fri Aug 06, 2021 8:47 am
"Well that escalated quickly..."
:lol:
Post by chunky79 » Fri Aug 06, 2021 9:30 am
:lol:
That individual is something else. For someone who claims to have been in the special forces (one of many things he likes to brag about) , he sure ain't got no balls!
mavada
Post by mavada » Fri Aug 06, 2021 12:38 pm
...did the right rear yesterday, with no frozen bolts and nuts i found it easier then the fronts.
Getting the lot out of the car and new in was a bit of a challenge...
First time suspension work, each corner took me a day incl. Removal of spring from old shock and install on new shocks :bash:
Yellow Koni's
steve2003rs6
Post by steve2003rs6 » Fri Aug 06, 2021 1:16 pm
Nice work Mav. That feeling of satisfaction!
Post by Shoppinit » Fri Aug 06, 2021 4:09 pm
It’s why I hate suspension work. Heavy and difficult.
mavada
Post by mavada » Fri Aug 06, 2021 4:43 pm
Yes it is, and i hate having my head inside the wheelarch when the rear axel/suspension is supported by axle stand (and for piece of mind, a jack supporting the car at the rear jack points...)
This way i managed to get every bolt and nut to the right nm spec with rear axle under load, did the same with the fronts.
I measured from the center driveshaft to edge wheelarch (+/-34, 35cm) as a guide prior to get the whole lot out, and knowing/hoping/ thinking the ride height with new rear konis on lowest setting was around stock height.
Lowering the jack, with axle stand supporting the rear suspension, till reaching the 34, 35cm , then all bolts and nuts spec nm.
Yellow Koni's
Users browsing this forum: Rs3, srichards and 69 guests
