Shortly to be a new rs6 c6 owner
Hello group!
After owning an audi rs2 (tribute) for more than 15years ending up knowing the ins and outs of the car, mapping It myself and producing around 500hp I'm going to make the leap to the C6 scene.
After reading through gently about the car, I have a few options locally, from a genuine stock car to a few modded mtm versions.
I'm either considering a stock version with around 100 to 140k km on the clock and then going for wagner ICs and a map OR get a 730hp mtm version.
Questions.
Would an already modded mtm version have already overstressed the turbos and therefore might not be a good idea?
Other than the usual culprits oil gasket leak, smoking turbos, is there anything else to look out for?
I plan obviously a full inspection and compression test before buying.
Many thanks
Vas
Questions.
Many thanks
Vas
Jim Haseltine
Re: Shortly to be a new rs6 c6 owner
Coolant pipes under the RH wheel arch. Other than that, it's a 10 year old car so under bonnet plastic pipes will be brittle if they've not already been replaced - some of the ribbed oil breather pipes on my car disintegrated the first time I touched them.
Perfect, good idea to check these too.
Hi and welcome to the C6 family! Compression test is a serious good idea, outer cilinders are fragile to overheating and cause piston ring/cilinder wall damage. Also check if the PCV is in 100% working order (some hoses can break or leak). I worked on one engine with a broken off PCV hose, just before the collector and this caused catastrophic failure since they just kept driving with it. If car has ceramics, check the ceramic wear indicators on the disks to see how far they have worn out. (Check google for images). Also just the pads - if ceramic will set your back 1100+ dollars for all 4 if they needs replacement original Audi.VaudiGR wrote: ↑Sun Jul 18, 2021 8:52 amHello group!
Questions.
Many thanks
Vas
Please also peek into the “V” of the 10 cilinder, between pipes of the air intake to see if there is oil on top there. Just like the o-ring, the head oil cooler also has rings that can dry out. I would recommend taking into consideration that almost all C6 need engine out jobs eventually, if this has not been done before with proof in form of pictures and invoices. Some have minor-minor leaks, some mayor - just like the dentist the chair is inevitable. Cheers from Holland! - oh and some pictures.
Wow thank you very much for all these photos.
I have now driven a sedan version which potentially has the 800hp mtm kit. However the greek mtm distributor is not easy to get hold of and word of mouth seems to suggest that he is not very trustworthy.
It will get an inspection from the audi dealers as well as my own and hopefully it will be OK.
Main selling point it has 46k km !!
Sent from my SM-G998B using Tapatalk
What's the type of gearbox oil to use other than the OEM?
Would anyone suggest 5w40 instead of 5w30 due to the Greek warmer climates?
Putting engine oil in the gearbox would be catastrophic I would think.
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
Haha, those were 2 separate questions
I was asking about the spec of the gearbox oil as there are aftermarket alternatives that are usually better
Users browsing this forum: Google [Bot] and 36 guests
