On the road again...
mavada
Re: On the road again...
Post by mavada » Thu Jul 08, 2021 6:08 pm
Ok thanks.
The koni users here, which rebound settings front and rear did you use? Numbers of turns from soft...
And which rideheight (only the rears are adjustable, i think lowest...)?
I like a bit firm ride, but not boneshakers firm...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
mavada
Post by mavada » Fri Jul 09, 2021 1:20 pm
So i made a start today dismantle the front suspension.
This bugger one is in rock solid, tried abusing the housing with a hammer, tried to turn the bold, nothing seems to work.
Sprayed with wd40 couple times.
Are there more options to get it loose without distroying the bold and drill it out?
Yellow Koni's
Post by Shoppinit » Fri Jul 09, 2021 1:28 pm
You have to remove the bolt to get the ball joints out. No way are they coming out if the bolt is still in situ.
mavada
Post by mavada » Fri Jul 09, 2021 1:29 pm
Yes i know, but its in rock solid:(
And im a master in distroying things...
Yellow Koni's
Post by Shoppinit » Fri Jul 09, 2021 1:30 pm
So you can't turn the bolt?
mavada
Post by mavada » Fri Jul 09, 2021 1:31 pm
No, maybe i have to try harder, but im afraid to sheer it off...
The nut was dead easy...
Yellow Koni's
Post by Shoppinit » Fri Jul 09, 2021 1:31 pm
Were you able to remove the nut?
mavada
Post by mavada » Fri Jul 09, 2021 1:32 pm
Yes easy:)
Yellow Koni's
Post by Shoppinit » Fri Jul 09, 2021 1:33 pm
Can't you drift out the bolt then?
Post by Shoppinit » Fri Jul 09, 2021 1:34 pm
Soak the whole lot in release oil for a few hours. WD40 isn't ideal.
Have you got a blow torch?
Post by Shoppinit » Fri Jul 09, 2021 1:35 pm
For the avoidance of doubt, this nut:
mavada
Post by mavada » Fri Jul 09, 2021 1:35 pm
Yes, thats off already.
No, i dont have air pressurized tools unfortunately.
I see of i can hammer on end of bold with piece of wood in between...
Yellow Koni's
mavada
Post by mavada » Fri Jul 09, 2021 1:38 pm
That f....ing bold i was already worry about before i started.
Yellow Koni's
Post by Shoppinit » Fri Jul 09, 2021 1:40 pm
Blow torch:
Yes, that's what drifting means.
*bolt
mavada
Post by mavada » Fri Jul 09, 2021 1:42 pm
Yellow Koni's
Users browsing this forum: 111marc111, Google Adsense [Bot] and 81 guests
