On the road again...
Re: On the road again...
Ok thanks.
The koni users here, which rebound settings front and rear did you use? Numbers of turns from soft...
And which rideheight (only the rears are adjustable, i think lowest...)?
I like a bit firm ride, but not boneshakers firm...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
So i made a start today dismantle the front suspension.
This bugger one is in rock solid, tried abusing the housing with a hammer, tried to turn the bold, nothing seems to work.
Sprayed with wd40 couple times.
Are there more options to get it loose without distroying the bold and drill it out?
Yellow Koni's
Yellow Koni's
You have to remove the bolt to get the ball joints out. No way are they coming out if the bolt is still in situ.
Yes i know, but its in rock solid:(
And im a master in distroying things...
Yellow Koni's
Yellow Koni's
So you can't turn the bolt?
No, maybe i have to try harder, but im afraid to sheer it off...
The nut was dead easy...
Yellow Koni's
Yellow Koni's
Were you able to remove the nut?
Yes easy:)
Yellow Koni's
Yellow Koni's
Can't you drift out the bolt then?
Soak the whole lot in release oil for a few hours. WD40 isn't ideal.
Have you got a blow torch?
For the avoidance of doubt, this nut:
Yes, thats off already.
No, i dont have air pressurized tools unfortunately.
I see of i can hammer on end of bold with piece of wood in between...
Yellow Koni's
Yellow Koni's
That f....ing bold i was already worry about before i started.
Yellow Koni's
Yellow Koni's
Blow torch:
Yes, that's what drifting means.
*bolt
Yellow Koni's
Yellow Koni's
Users browsing this forum: srichards and 69 guests
