The high pressure side starts at >150psi or so and then drops once it's got going and the air is cold.
I suspect I’ll be buying a vacuum pump soon, just because...
This is with AC set to max cold, right?
You'd need a gas recovery system, too, if you intend to do any work on the system. And a way to accurately measure the amount of gas (and PAG oil) to go back in.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 240 guests
