Aircon not working diagnosis
Mɐʇʇ
Re: Aircon not working diagnosis
Post by Mɐʇʇ » Tue Jun 29, 2021 12:47 pm
Well it all looks professional. No idea what I’m doing though. :mrgreen:
The high pressure side starts at >150psi or so and then drops once it's got going and the air is cold.
I suspect I’ll be buying a vacuum pump soon, just because...
Post by Shoppinit » Tue Jun 29, 2021 1:18 pm
High side seems a bit low. What are your static pressures (engine off and cold)?
Mɐʇʇ
Post by Mɐʇʇ » Tue Jun 29, 2021 1:31 pm
Yeah, it started higher and then dropped. It does pump out proper cold air though - so something is working.
I thought I took a pic of the pressure engine off & all cold - but fat fingers. Will have another go.
Post by Shoppinit » Tue Jun 29, 2021 2:38 pm
This is with AC set to max cold, right?
You'd need a gas recovery system, too, if you intend to do any work on the system. And a way to accurately measure the amount of gas (and PAG oil) to go back in.
Mɐʇʇ
Post by Mɐʇʇ » Tue Jun 29, 2021 2:42 pm
I thought it was just a good set of scales to measure gas going back in?
Anyway, I should stop this line of thought. I have enough tools in the garage as it is....if it's broken, I'll fix it and then get kwikfit or whoever to vacuum & recharge it with the machine.
Which reminds me of the fix on my old Saab. The high pressure line had corroded through from before we bought it. So I rigged up an adaptor to the compressor to pressurise it and find the leak. Then a bit of JB Weld, couple of hose clamps and a bit of tube that fit snugly round the outside to make a patch and bingo - aircon fixed without having to take the whole front of the car off, not even the bumper, to get working aircon again.
Post by Shoppinit » Tue Jun 29, 2021 2:49 pm
Brilliant. I am pretty sure this is what has happened to my 9000, a lot of corrosion around the high pressure switch. Anyway, it all looks far too corroded to try and fix. Suspect I am going to let the car go after the next MOT anyway.
Mɐʇʇ
Post by Mɐʇʇ » Tue Jun 29, 2021 6:40 pm
Engine off and cold.
Post by Shoppinit » Tue Jun 29, 2021 6:54 pm
Looks about right. But there’s only so much you can tell from the pressures.
Mɐʇʇ
Post by Mɐʇʇ » Tue Jun 29, 2021 6:57 pm
Thank you.
Users browsing this forum: No registered users and 263 guests
