Leak
GusGus67
Re: Leak
Post by GusGus67 » Fri Feb 26, 2021 12:28 pm
That would be helpful. My screen is due to be done on Wednesday
bilko1
Re: Leak
Post by bilko1 » Fri Feb 26, 2021 11:16 pm
It took Autoglass 3 attempts to get the right screen for mine.
Steve2003rs6
Re: Leak
Post by Steve2003rs6 » Sat Feb 27, 2021 9:19 am
Wait until you attempt to replace the rear screen.
Two screens fitted two screens exploded when you put the demister on.
Eventually put the original back in.
See page 3 titled shattered rear windscreen.
Lander91
Re: Leak
Post by Lander91 » Sun Feb 28, 2021 8:14 pm
Sorry gus, gents. We went into level 3 lockdown yesterday for 7 days so I can't go into work :x
Steve2003rs6
Re: Leak
Post by Steve2003rs6 » Thu Jun 24, 2021 12:04 pm
Lander. Did you manage to obtain the correct screen sizes.
Lander91
Re: Leak
Post by Lander91 » Fri Jun 25, 2021 1:02 am
Good timing, indeed I have. The top and bottom integrated seals made things a bit tricky.
Dimensions as follows (approx/best reckoning) in mm:
A 1453
B 1145
C 804
D 893
E 904
Lander91
Re: Leak
Post by Lander91 » Fri Jun 25, 2021 1:07 am
Reference images.
Steve2003rs6
Re: Leak
Post by Steve2003rs6 » Fri Jun 25, 2021 8:06 am
Thanks for that mate.
I had a new screen and plastic water deflector installed a few months ago and I am not happy with it.
I now have 3 stone chips in the screen so another screen is going to be installed.
I want to get it right this time for obvious reasons.
Dimension E and C are the measurements I am particularly interested in.
I wonder is the Rs6 screen is different to the A6 screen.
Steve2003rs6
Re: Leak
Post by Steve2003rs6 » Fri Jun 25, 2021 9:29 am
Auto glass provided my front and rear screens.
I was also unhappy with the fitting.
Ended up with a gap at the bottom of the screen and the dashboard. Causing vibration noise. Inserted rubber packing to eliminate the noise which was driving me nuts.
The installer didn’t remove all of the old bonding. Put new bond on top of what was left of the old.
Hence the new screen doesn’t sit back far enough.
Re: Leak
Post by Shoppinit » Fri Jun 25, 2021 9:31 am
I would only get a screen supplied and fitted by Audi. If they are even still available.
Steve2003rs6
Re: Leak
Post by Steve2003rs6 » Fri Jun 25, 2021 9:47 am
Yes shopp. I am going to Audi this time.
After two rear screens exploding. Put the original rear screen back in.
And the front screen is not perfect.
This all started to rectify some paint bubbling of the roof rails. I was really happy with the bodywork and paintwork.
The screens was a big letdown.
But it will get sorted.
Ps lander who supplied your screen and what did they charge you.
Steve2003rs6
Re: Leak
Post by Steve2003rs6 » Sat Jun 26, 2021 3:07 pm
Just as I thought. The new screen that was fitted is too short.
Will contact Audi on Monday and see if they can get one.
Lander91
Re: Leak
Post by Lander91 » Sat Jun 26, 2021 10:38 pm
Fyi manufacturer is Pilkingtons
Steve2003rs6
Re: Leak
Post by Steve2003rs6 » Sun Jun 27, 2021 9:18 am
Hi lander.
Did you order direct from pilkintons or through auto glass.
Out of interest Who did the installation.
Lander91
Re: Leak
Post by Lander91 » Sun Jun 27, 2021 11:27 am
Neither, my screen is fine (for now). The screen is in stock (5 or 6) at the national the Audi genuine parts warehouse, got this one down off the racks just to measure up for you. Pilkingtons is printed on the screen.
