Gearbox Engine Oil Cooler Upgrade
Lander91
Re: Gearbox Engine Oil Cooler Upgrade
Post by Lander91 » Mon Jun 21, 2021 8:17 pm
That's a realy good looking setup Jayjay. Reckon you could do a bit of a detailed spec summary for us? (Unless you already have, if so apologies)
Mɐʇʇ
Post by Mɐʇʇ » Mon Jun 21, 2021 8:19 pm
Very nice
Jayjay101
Post by Jayjay101 » Mon Jun 21, 2021 8:37 pm
Lander91 wrote:That's a realy good looking setup Jayjay. Reckon you could do a bit of a detailed spec summary for us? (Unless you already have, if so apologies)
Yes mate-like I said there 19 row coolers for both gearbox and engine.an10 fittings 2x45 degrees and 6 straight along with a adapter for a oil temperature sender on the gearbox side,I’ve just screwed into the OEM fittings for now so you need(I think) 2xm18 to an10 and 2x m22 to an10. The brackets to hang them off are easy to fab up and I used mounting points that are on the rad and I’ve by passed that too.also have a new power steering cooler mounted behind the passenger side intercoolers that’s normally used as a motorbike engine oil cooler.I did have to trim the bumper support a bit.I’ll get some more photos.
Jayjay101
Post by Jayjay101 » Mon Jun 21, 2021 8:39 pm
Mɐʇʇ wrote:Very nice
Thanks mate
Jayjay101
Post by Jayjay101 » Mon Jun 21, 2021 8:43 pm
Power steering cooler.
Jayjay101
Post by Jayjay101 » Mon Jun 21, 2021 8:45 pm
Gearbox side.
Jayjay101
Post by Jayjay101 » Mon Jun 21, 2021 8:49 pm
These are the an to metric fittings.
Lander91
Post by Lander91 » Thu Jun 24, 2021 9:35 am
Sh*t hot Jayjay, thank you!
RS6Rottweiler
Post by RS6Rottweiler » Tue Jul 06, 2021 1:54 pm
I bought a new cooler form Audi but no hoses available so will have to make them all, does anyone know what AN10 fitting will go direct onto the cooler rather than use the female adaptor or is the adaptor the only solution? Also what size is the the upper fittings that go to the gearbox and what fitting will go direct onto the cooler or do I have to use the female adaptor solution? I think this pipe is smaller so will be AN8, can anyone confirm? Anyone got the Torqyes part numbers.
I would appreciate any help you guys can give me as I need to get the car back on the road as soon as if possible?
Jayjay101
Post by Jayjay101 » Tue Jul 06, 2021 1:59 pm
RS6Rottweiler wrote:I bought a new cooler form Audi but no hoses available so will have to make them all, does anyone know what AN10 fitting will go direct onto the cooler rather than use the female adaptor or is the adaptor the only solution? Also what size is the the upper fittings that go to the gearbox and what fitting will go direct onto the cooler or do I have to use the female adaptor solution? I think this pipe is smaller so will be AN8, can anyone confirm? Anyone got the Torqyes part numbers.
All audi fittings are metric(m18 for the gearbox and m22 for engine oil)-all my hose is an10
RS6Rottweiler
Post by RS6Rottweiler » Tue Jul 06, 2021 2:47 pm
Thanks JayJay101, I assume they are both 18 & 22 x 1.5? Did you use the female adaptor or did you get AN10 fittings straight onto the cooler?
660z
Post by 660z » Mon Jan 24, 2022 4:26 am
That looks much better than stock, what kind of money did that cost and would you consider replicating it for sale ?
Jayjay101
Post by Jayjay101 » Wed Jan 26, 2022 2:30 pm
660z wrote:That looks much better than stock, what kind of money did that cost and would you consider replicating it for sale ?
Less than £300 in parts I think
Users browsing this forum: Bing [Bot] and 188 guests
