Gearbox Engine Oil Cooler Upgrade
Re: Gearbox Engine Oil Cooler Upgrade
That's a realy good looking setup Jayjay. Reckon you could do a bit of a detailed spec summary for us? (Unless you already have, if so apologies)
Very nice
Yes mate-like I said there 19 row coolers for both gearbox and engine.an10 fittings 2x45 degrees and 6 straight along with a adapter for a oil temperature sender on the gearbox side,I’ve just screwed into the OEM fittings for now so you need(I think) 2xm18 to an10 and 2x m22 to an10. The brackets to hang them off are easy to fab up and I used mounting points that are on the rad and I’ve by passed that too.also have a new power steering cooler mounted behind the passenger side intercoolers that’s normally used as a motorbike engine oil cooler.I did have to trim the bumper support a bit.I’ll get some more photos.Lander91 wrote:That's a realy good looking setup Jayjay. Reckon you could do a bit of a detailed spec summary for us? (Unless you already have, if so apologies)
Thanks mateMɐʇʇ wrote:Very nice
Power steering cooler.
Gearbox side.
These are the an to metric fittings.
Sh*t hot Jayjay, thank you!
RS6Rottweiler
I bought a new cooler form Audi but no hoses available so will have to make them all, does anyone know what AN10 fitting will go direct onto the cooler rather than use the female adaptor or is the adaptor the only solution? Also what size is the the upper fittings that go to the gearbox and what fitting will go direct onto the cooler or do I have to use the female adaptor solution? I think this pipe is smaller so will be AN8, can anyone confirm? Anyone got the Torqyes part numbers.
I would appreciate any help you guys can give me as I need to get the car back on the road as soon as if possible?
All audi fittings are metric(m18 for the gearbox and m22 for engine oil)-all my hose is an10RS6Rottweiler wrote:I bought a new cooler form Audi but no hoses available so will have to make them all, does anyone know what AN10 fitting will go direct onto the cooler rather than use the female adaptor or is the adaptor the only solution? Also what size is the the upper fittings that go to the gearbox and what fitting will go direct onto the cooler or do I have to use the female adaptor solution? I think this pipe is smaller so will be AN8, can anyone confirm? Anyone got the Torqyes part numbers.
RS6Rottweiler
Thanks JayJay101, I assume they are both 18 & 22 x 1.5? Did you use the female adaptor or did you get AN10 fittings straight onto the cooler?
That looks much better than stock, what kind of money did that cost and would you consider replicating it for sale ?
Less than £300 in parts I think660z wrote:That looks much better than stock, what kind of money did that cost and would you consider replicating it for sale ?
Users browsing this forum: Bing [Bot] and 173 guests
