Bad oil leak?
RS6Rottweiler
Bad oil leak?
Needing some help, I have a very bad oil leak that is visible only from the front drivers side front bumper bumper area under the lower air intake, fog Lamy area, you can't see a thing without dismantling the bumper etc but wondered if anyone had an idea what or where this might be coming from, nothing obvious around the filter cooler area and I believe the pump is on the other side but it is pouring out so any ideas or help with possible know problem areas would be greatly appreciated./
Re: Bad oil leak?
Hi mate
I would say it’s coming from one of the engine oil cooler pipes because they run in that area.
Best thing to do is remove the under tray and have a look.
Re: Bad oil leak?
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
- simonpoulton
Re: Bad oil leak?
+1 for the oil cooler pipes - that's exactly where my one went. For me it was the solid pipe.
Past: R56 Mini Cooper S
RS6Rottweiler
Re: Bad oil leak?
Thanks for the tips guys, just waiting to get it on a hoist so they can have a look. I have ordered the parts up to replace the hose if that's what it is, if its the solid pipe is there a fix for that or buy a new one?
Users browsing this forum: Google [Bot] and 65 guests
