Bad oil leak?
RS6Rottweiler
Bad oil leak?
Post by RS6Rottweiler » Wed Jun 02, 2021 5:07 pm
Needing some help, I have a very bad oil leak that is visible only from the front drivers side front bumper bumper area under the lower air intake, fog Lamy area, you can't see a thing without dismantling the bumper etc but wondered if anyone had an idea what or where this might be coming from, nothing obvious around the filter cooler area and I believe the pump is on the other side but it is pouring out so any ideas or help with possible know problem areas would be greatly appreciated./
Riggs
Re: Bad oil leak?
Post by Riggs » Wed Jun 02, 2021 7:16 pm
Hi mate
I would say it’s coming from one of the engine oil cooler pipes because they run in that area.
Best thing to do is remove the under tray and have a look.
Classik
Re: Bad oil leak?
Post by Classik » Wed Jun 02, 2021 7:54 pm
RS6 C5 Avant 2003 Daytona Grey
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
simonpoulton
Re: Bad oil leak?
Post by simonpoulton » Thu Jun 03, 2021 6:38 pm
+1 for the oil cooler pipes - that's exactly where my one went. For me it was the solid pipe.
Past: R56 Mini Cooper S
RS6Rottweiler
Re: Bad oil leak?
Post by RS6Rottweiler » Sat Jun 05, 2021 9:19 am
Thanks for the tips guys, just waiting to get it on a hoist so they can have a look. I have ordered the parts up to replace the hose if that's what it is, if its the solid pipe is there a fix for that or buy a new one?
