Engine rebuild
- IchBautAuto
Engine rebuild
I'm in a happy place where my RS6 requires no work..at all! I have had a spare complete AZR engine for the RS4 since 2015 and it's about time it was refurbished and waiting to be used. It ingested a foreign object in the PO car and did a piston and lightly scored the bore of No 6.
A quick strip down. Very lucky to have all the more unusual tools to hand so it was a very easy task. Surprisingly the bearings exhibited a little wear which is a bit unusual but the crank was perfect.
The block is now ready to head off for machining. I'm have 82mm Woessner pistons ready to go. All expectations are that machining will remove the score and other superficial damage. I have most parts for the rebuild, bearings, full set of ARP studs, new turbos, new heads, loba cams, most seals and gaskets, tube manifolds and so on. Just a matter of joining the various queues for machining etc.
- IchBautAuto
Re: Engine rebuild
Well, as expected. some gaskets are NLA from the factory but are available from aftermarket sources. Onlinecarparts UK are a good source UNTIL they want to charge 108 pounds for a 16 pound gasket to be shipped to Australia. The same product from EBay (ex UK) or Europe is about 20 pounds shipping. Clearly a case of business not wanted here. Otherwise their prices are comparable.
- IchBautAuto
Re: Engine rebuild
On the way to the machine Shop. Reminds me of the two engined mini.
- IchBautAuto
Re: Engine rebuild
and it's home again
New capacity 2737cc.
Big clean first and then will get the bottom end and Woessner pistons in while procrastinating about whether to use the Loba mechanical cams or the originals.
- IchBautAuto
Re: Engine rebuild
Progressing, there are a few fiddly jobs before the clean is complete and then assembly starts.
Multi-tasking, finalising the parts for the turbo refurb and finding adjustable wastegate actuators hasn't been as straight forward as it once was. Mr google has only thrown up a couple of options, all from the US. I'm looking at around 10 psi but that may not be optimum so the ability to swap springs will make life a little easier. I've settled for Mamba as the other vendors were slooow in arranging a sale.
- IchBautAuto
Re: Engine rebuild
Mambas are here, so another piece of the puzzle sorted. At this stage other than a few o rings and small gaskets I have all the parts ready to start the build up.
Woessner 82mm pistons
UK manifolds
+15 clutch
The cams are a yet to be confirmed option at this stage as the added lash adjustment is a PIA.
Sticking with factory rods, bearings etc. Turbo specs still on the drawing board as this is a street car to be driven, not a coffee bar car that is all about brands and unuseable top end power.
- IchBautAuto
Re: Engine rebuild
Slight delay in progress while I fitted electric garage doors, learnt how to do mirror art, fitted a few reversing cameras and found out that the chemical clean of the block wasn't anywhere near as good as it was supposed to be. Basically there are a lot of internal O 'rings inside the engine and none of the sealing surfaces were up to my standard so tiny wire brushes and a dremel tool needed to clean the sealing surfaces before progressing further.
Re: Engine rebuild
Any further progress with the engine build?
Users browsing this forum: Google [Bot] and 10 guests
