Gearbox Teardown & Refurbish - 6HP28A61
Re: Gearbox Teardown & Refurbish - 6HP28A61
Intermediate output shaft
... and I can confirm these are a ball ache to remove stripped every single one on both coolersATinOf wrote: ↑Mon Sep 03, 2018 12:24 pmNow to remove the oil coolers, starting with the transfer diff oil cooler. It seems we have some more screws to order; malgrips put to use again!
These screws are Audi supply; 01V 919 838, although they are the same M6 x 15 Torx fixings as the cooler pipe screw; ZF dont list them for the gear oil coolers.
After the transfer diff cooler remove the gearbox oil cooler adjacent
Transfer case magnet
The bearing in the transfer case seems to have lot of play when the output shaft is out maybe this is normal
maybe At can comment on this.
Finally got the oil coolers off by making a t30 fit in a t25
Don’t worry your sump bolts won’t be as mix matched as mine
Does anyone know what this bolt is
welwynnick
That's an E-torx bolt / hexalobular head screw.
Sometimes you can undo them with a wall-drive hex socket or a bi-hex socket, but for modern German cars it's best to have a proper set of E-Torx sockets, and I wouldn't risk it.
Nick
Nick
I’ve got proper torx se but this is external I just put a 9mm socket and it came off thanks anyway
Does anyone know what these two are for front diff? Next to the oil coolers
Sump looks clean but then again it had oil and filter to see if it would fix it remember to inspect the magnets
Got the sump off everything looks clean At has two blue solenoids and I have two green ?
Got the main torx that hold the it to the gearbox but it wouldn’t budge I suspect that this selector is interfering.
Be careful when turning the box over there’s “overflow” in the bell housing oil will leak
Jim Haseltine
