TCU
Hixrs6
TCU
Post by Hixrs6 » Mon Nov 09, 2020 3:47 pm
Hey guys,
Anyone know how to log TCU currents or anything like it via vag com?
Had a solenoid code and replaced all the solenoids and still have the code. Want to try everything before just buying another TCU.
Thank you!
Re: TCU
Post by Shoppinit » Mon Nov 09, 2020 3:58 pm
Logs measuring blocks 005 and 006 along with group 001 to get the input rpms and current gear.
Remind me what your error codes are?
Hixrs6
Re: TCU
Post by Hixrs6 » Mon Nov 09, 2020 5:14 pm
Thank you sir.
Re: TCU
Post by Shoppinit » Mon Nov 09, 2020 6:27 pm
So many fault codes that could all be explained by a bad 16-pin connector at the gear box. Or a bad TCU.
How do you feel about measuring resistance?
Hixrs6
Re: TCU
Post by Hixrs6 » Mon Nov 09, 2020 8:52 pm
I measured the resistance on the harness at the front that’s known to corrode because of the seals
And it was fine. Used contact cleaner and reconnected. I haven’t been able to find a spare TCU to try out I live in Canada and there’s not many of these here
Re: TCU
Post by Shoppinit » Mon Nov 09, 2020 10:49 pm
Plug it back in and unplug from the TCU to check the resistances.
Re: TCU
Post by Shoppinit » Mon Nov 09, 2020 10:56 pm
Measure between pins:
52 & 53
33 & 52
33 & 34
32 & 52
32 & 34
Ignition off.
Hixrs6
Re: TCU
Post by Hixrs6 » Mon Nov 09, 2020 11:55 pm
Thank you very much I’ll try that tonight.
Testing the pins attached to the harness that you pull out of the TCU correct?
Re: TCU
Post by Shoppinit » Tue Nov 10, 2020 9:35 am
Yup.
Hixrs6
Re: TCU
Post by Hixrs6 » Tue Nov 10, 2020 5:01 pm
52 & 53 nothing
33 & 52 28 ohms
33 & 34 nothing
32 & 52 27.7 ohms
32 & 34 nothing
Couldn’t do the logs because I can’t get it out of limp mode right now even after clearing codes etc.
Re: TCU
Post by Shoppinit » Tue Nov 10, 2020 6:01 pm
When you say nothing do you mean zero or infinity?
Hixrs6
Re: TCU
Post by Hixrs6 » Tue Nov 10, 2020 6:53 pm
It says “1.” on the screen when it’s on but you’re not using it and when I test between those three pins, the screen doesn’t change
Re: TCU
Post by Shoppinit » Tue Nov 10, 2020 7:01 pm
OK. Then infinity.
So what you measured is all as I would expect it to be.
That would suggest it's not the 16 pin connector and not the solenoids. So maybe a bad TCU.
Where in Canada are you?
Hixrs6
Re: TCU
Post by Hixrs6 » Tue Nov 10, 2020 7:21 pm
OK. Then infinity.
Niagara Falls Ontario.
My tuner said he would be able to take apart the TCU and diagnose and fix if he can for around C$400 although I don’t really see a very good track record when people Muck around with the tcu
Re: TCU
Post by Shoppinit » Tue Nov 10, 2020 7:33 pm
You could try calling Xemodex to see if they can do anything. They’re in Ontario IIRC. I don’t know if they do anything on the RS6 TCU though.
Users browsing this forum: Google Adsense [Bot] and 212 guests
