Positive Crankcase Ventilation Valve
N11LS_J
Post by N11LS_J » Mon Aug 24, 2020 1:34 am
Hi guys
So my 2013 RS6 started whistling after a long 300 mile drive as I pulled into my destination, this may have happened long before my arrival and I may not have noticed the sound, however I did notice a lack in power for the last 50 odd miles.
There were no warning lights either until the day after when the engine management light popped up.
Having had a quick google search, I came across a possible PCV valve failure, anyone experienced this?
If so, any ideas on the location of this valve and work involved?
Nils
Instagram : n_i_l_s
Golfather
Re: Positive Crankcase Ventilation Valve
Post by Golfather » Mon Aug 24, 2020 1:08 pm
Full front end strip down Nils
Do the oil screen as well whilst you are in there
This was a recall over in the states, so you maybe able to argue the case using the technical bulletin at your local stealer.
https://testing-public.carmd.com/Tsb/Do ... 35/A171562
N11LS_J
Post by N11LS_J » Mon Aug 24, 2020 1:11 pm
Ah legend, thought this may be the case, thanks for that 🙏🏽
Instagram : n_i_l_s
Hop along scott
Post by Hop along scott » Tue Aug 25, 2020 9:41 pm
My old RS6 c7 had it changed. I believe it's under the turbos somewhere. Big job. So glad that car got returned and refunded.
Tadass910
Post by Tadass910 » Wed Aug 26, 2020 9:16 pm
Do all c7 Rs6 have this problem?
Golfather
Post by Golfather » Thu Aug 27, 2020 1:05 am
Common to all 4.0T
Tadass910
Post by Tadass910 » Thu Aug 27, 2020 9:13 pm
Common to all 4.0T
:audibash:
