Hi guys
So my 2013 RS6 started whistling after a long 300 mile drive as I pulled into my destination, this may have happened long before my arrival and I may not have noticed the sound, however I did notice a lack in power for the last 50 odd miles.
There were no warning lights either until the day after when the engine management light popped up.
Having had a quick google search, I came across a possible PCV valve failure, anyone experienced this?
If so, any ideas on the location of this valve and work involved?
Nils
Positive Crankcase Ventilation Valve
Re: Positive Crankcase Ventilation Valve
Full front end strip down Nils
Do the oil screen as well whilst you are in there
This was a recall over in the states, so you maybe able to argue the case using the technical bulletin at your local stealer.
https://testing-public.carmd.com/Tsb/Do ... 35/A171562
Ah legend, thought this may be the case, thanks for that
Instagram : n_i_l_s
Hop along scott
My old RS6 c7 had it changed. I believe it's under the turbos somewhere. Big job. So glad that car got returned and refunded.
Do all c7 Rs6 have this problem?
Common to all 4.0T
Users browsing this forum: No registered users and 147 guests
