Recommendations for Audi servicing in Kent
maars
Post by maars » Mon Aug 17, 2020 11:59 am
Looking for a decent independent Audi specialist in Kent/SE London to do some work on my RS4.
Who do you recommend? :thumbs:
Daytona RS4 Avant - black optics/decat downpipes/H-pipe/KW springs - featured on the 2012 Audi stand at the Goodwood FoS
The_Coat
Re: Recommendations for Audi servicing in Kent
Post by The_Coat » Mon Aug 17, 2020 4:32 pm
4 Rings in Dartford always get good reviews.
Sent from my Pixel 2 using Tapatalk
RS4 Avant - Misano Red
NickvRS4
Post by NickvRS4 » Sun Aug 23, 2020 9:25 pm
Kent Automotive in Maidstone are Audi specialists.
These guys are brilliant 👍🏻
delroyx
Post by delroyx » Mon Aug 24, 2020 11:49 am
Kent Automotive ripped me off. I used them a few times including fitting my coilovers. At the same time they allegedly changed the top arms. Within a year the car was back there for something else, and as part of their inspection they told me i needed new top arms! Either fishing for work or they didn't change them in the first place!
Also charged me £50 to run a scan to confim the TPMS antenna had gone which I had already diagnosed but wanted confirmation. Car was plugged in for about 2mins. The guy who did it wasn't gonna charge me but Aaron said it was £50 for cash for £50 plus VAT if I wanted a receipt.
Also, they have virtually no parking, so you risk getting your car damaged in the street or a wheel kerbed. My wingmirror got damaged whilst there but didn't notice until a day or so later. With Aaron's bad attitude & approach to customer service I knew it wasn't worth it.
I'm going to try 4 Rings in the future.
maars
Post by maars » Mon Aug 24, 2020 12:26 pm
Thanks for the tip :thumbs:
I've used 4Rings before, and wouldn't recommend them either.
Why is it so hard to find a decent garage...
delroyx
Post by delroyx » Fri Sep 11, 2020 5:39 pm
@maars - did you ever did find a decent garage?
maars
Post by maars » Fri Sep 11, 2020 5:48 pm
CamSpec in Crawley are excellent, but quite a distance from me.
m5killer
Post by m5killer » Fri Sep 11, 2020 8:40 pm
Qst Kim Collins is your best bet not too far from Kent
delroyx
Post by delroyx » Sat Sep 12, 2020 9:37 am
👍 Thanks. They are both about the same distance from me so I'll give them both a shout
maars
Post by maars » Sat Sep 12, 2020 10:25 am
QST are more for tuning, CamSpec more for maintenance.
Depends what you need doing @delroyx
delroyx
Post by delroyx » Sat Sep 12, 2020 6:51 pm
First thing I want to do is increase the ride height. My KWs are set just a tad too low. Should be straight forward. I'd do it my self but my drive is on a bit of a slope & don't fancy the risk. Looking at QSTs website they should be able to do it easily as they supply KW.
maars
Post by maars » Sat Sep 12, 2020 8:10 pm
Which KWs do you have? Coilovers or height adjustable springs with DRC dampers? I have the latter, but you’re right - easier to get the garage to adjust it. Plus it’s worth getting a 4 wheel alignment check afterwards. Both QST and CamSpec can do that.
delroyx
Post by delroyx » Sun Sep 13, 2020 10:07 am
Coilovers - v3. I've messaged both. CamSpec have already replied. I'll see if QST reply. Thanks for the recommendations. 🤞 They'll do a good job
maars
Post by maars » Sun Sep 13, 2020 7:07 pm
CamSpec fitted my KW adjustable spring kit and set up the geometry. They did a brilliant job.
delroyx
Post by delroyx » Sat Oct 10, 2020 2:06 pm
I messaged both QST & Camspec. David @ Camspec replied one Saturday evening. We exchanged a few messages & I booked my car in last Monday.
QST never replied.
David was very friendly & helpful & pointed me in the direction of a decent cafe near by. Anyway or couple or so hours later & the car was raised & aligned. The front is maybe 5mm at most too high, but David said to give it a bit of time & a few miles & see if it settles. If not he'd drop it at no extra charge.
I know it was far from a big job but so far so good with Camspec. Friendly, helpful, efficient, good workmanship & decent parking.
Worth considering for anyone in Kent/Sussex/Surrey as reliable garages seem few & far between.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 100 guests
