Air suspension fault code
jds67
Post by jds67 » Tue Jan 28, 2020 8:43 pm
I have recently had lowering links fitted and set approximately 15mm lower than standard. This done by putting the system into service mode , putting the suspension into the highest setting. Changed the links switched the vehicle back on put it into comfort mode then into dynamic and the vehicle sits how I want it. Drove it for a day no issues. Today it has thrown up air suspension fault and adaptive light fault? Why would this be and how can it be rectified? Thanks in advance.
Re: Air suspension fault code
Post by MikeFish » Tue Jan 28, 2020 8:51 pm
You checked none of the new links haven't come loose / fallen off or snapped?
jds67
Post by jds67 » Tue Jan 28, 2020 9:07 pm
All connected Mike?
Post by MikeFish » Tue Jan 28, 2020 9:44 pm
Might need to plug an OBD reader of some sort like VCDS / Carista / OBDEleven etc to read the fault code unless anyone has any other ideas?
jds67
Post by jds67 » Wed Jan 29, 2020 7:46 am
Ok anyone near Birmingham could do that?
