Air suspension fault code
I have recently had lowering links fitted and set approximately 15mm lower than standard. This done by putting the system into service mode , putting the suspension into the highest setting. Changed the links switched the vehicle back on put it into comfort mode then into dynamic and the vehicle sits how I want it. Drove it for a day no issues. Today it has thrown up air suspension fault and adaptive light fault? Why would this be and how can it be rectified? Thanks in advance.
Re: Air suspension fault code
You checked none of the new links haven't come loose / fallen off or snapped?
All connected Mike?
Might need to plug an OBD reader of some sort like VCDS / Carista / OBDEleven etc to read the fault code unless anyone has any other ideas?
Ok anyone near Birmingham could do that?
Users browsing this forum: No registered users and 70 guests
