oil change ?
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
Rees4
oil change ?
Post by Rees4 » Wed Jan 11, 2006 3:17 pm
Hi all,ive just received oil filter and sump bolt and washer via 'vag parts' ready for an oil change on my baby.Its 6.5k miles since last oil change and im unsure to wot oil i should go for.Ive checked out other posts on this subject and it seems that many of you fellas recomend different oils for winter and summer,well wot a bummer its january and im inbetween the two.Any ideas?
s4woody
Post by s4woody » Wed Jan 11, 2006 3:38 pm
if its really your baby i,d use baby oil.. :roll: :bash: :redrs4: (sorry i couldn,t resist it..
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Jan 11, 2006 3:45 pm
Run my car on millers 10w60 oil all year round. change oil and filter around 5k.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
kevinw
Post by kevinw » Wed Jan 11, 2006 3:47 pm
My choice is always mobil 1 ow40. Others will probably disagree. Change every 5k.
Rees4
Post by Rees4 » Wed Jan 11, 2006 3:53 pm
Bret,you car is highly modded,mines standard, would this make a difference in choice of oil?
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Jan 11, 2006 4:47 pm
Good oil is good oil. Standard of modded car. All the mod's to my car are bolt on, So the engine is the same.
MING BLUE AUDI S4
Car is on Lock down
JonnyX
Post by JonnyX » Wed Jan 11, 2006 6:09 pm
M1 0w40 for me. Just change it every 5k or so.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
flashyg
Post by flashyg » Wed Jan 11, 2006 10:27 pm
millers 10-60 is the best oil u can buy for it. trust the info!
good advice a seconded.
tartan_rob
Post by tartan_rob » Thu Jan 12, 2006 8:57 am
best you can afford. Better to save a little though and change more frequently..but just MO.
There are loads of posts on this. A qucik search may prove beneficial.
2017 Kawasaki Z1000
2014 RS6
2014 S1
eddiecrawford
Post by eddiecrawford » Thu Jan 12, 2006 9:56 am
synta gold from dealers
every 5k
Dippy
Post by Dippy » Thu Jan 12, 2006 3:09 pm
Whilst I agree with Brett that good oil is good oil, I do not agree that the engines are the same. Of course if Brett admits that he doesn't use the advantages that his mods give then its a different matter. But more importantly he has KO4 turbos and a recently rebuilt engine which is different from an original engine using KO3s.
Rees, Audi recommend 0W30. The 0 is the key figure because it indicates the viscosity of the oil when cold, and this is critical for turbos when the engine starts. In a temperate climate this is not too much an issue, however when temps are sub zero it can be. This is why IMHO it's best to use 0 instead of 10 in the winter. Our recent cold spells justify that.
Now as to the hot viscosity, there has been evidence from at least one respected tuner that grade 30 oil is too thin for the biturbo and risks early cam wear. That's enough reason for me at least to use grade 40 or more. Now you can use grade 60, but I'll stick my neck out here and suggest that it'll lose you a bit of performance and make the engine run hotter. Other than that it's perfectly fine, except that I doubt you'll find a multigrade less than 10W60 (cold).
So my recommendation is as follows:
Stock car: 0W40 all-year
Stage I or II (KO3s): 0W40 in winter and something better such as 15W50 in summer
Brett's probably fine with 10W60 all-year, but personally I'd be a bit careful in the sub-zero weather.
2001 Silver S4 Avant
Jez
Post by Jez » Thu Jan 12, 2006 11:04 pm
I'm also using synta gold from the dealers every 5k. This is what two seperate Audi stealers recommended to me... perhaps they just wanted my money :oops:
dazzer
Post by dazzer » Thu Jan 12, 2006 11:30 pm
Good post Dippy - thanks
dazzer
rsdreamer
Post by rsdreamer » Fri Jan 13, 2006 9:15 am
Good information Dippy.
Your thoughts are especially crucial at this time of year if your car is kept outside, and possibly only used on short distances when starting from cold.
As for the regime, I changed mine from Audi's 'Longlife schedule' to every 5000 miles or so when I bought mine 18 months ago on the advice of this forum, and looking forward to long life K03's.
With the costs of engine work so high, surely it's a no-brainer to change oil and filter 2 or 3 times a year.
rsdreamer.
:yellowrs4:
Return to “Audi S and RS Ownership”
Users browsing this forum: No registered users and 65 guests
