Camshaft Timing
Re: Camshaft Timing
Post by Shoppinit » Fri Jan 03, 2020 7:15 pm
Have a search on Google for "VCDS camshaft chain stretch". From what I can see on this problem that affects some VAG engines (not ours AFAIK) it looks like the group 93 timing becomes progressively more negative as the chain stretches. This would imply that as the chain stretches, the camshaft doesn't turn as much as it should and lags behind the crank.
Not sure if that proves you or me right. :bash:
/you, by the look of it, reading back.
//Although this is deduced from VCDS data on a completely different engine. I am pretty sure the K in KW means kurbelwinkel = Crank Angle.
Mɐʇʇ
Re: Camshaft Timing
Post by Mɐʇʇ » Fri Jan 03, 2020 7:35 pm
re 093 being in elsawin - I'm being blind - where is it?
The only reference I found in elsawin is what I printed to a pdf above - referencing 090 and 094 I think?
This is under Power Unit => 8 Cyl Engine => Engine Cylinder Head, Valve Gear => Checking Variable Valve Timing => Testing The System:
Mɐʇʇ
Re: Camshaft Timing
P.S. If anyone wants a copy of elsawin, just shoot me a PM.
Re: Camshaft Timing
Post by Shoppinit » Fri Jan 03, 2020 7:37 pm
Is it one on a virtual machine?
Mɐʇʇ
Re: Camshaft Timing
Post by Mɐʇʇ » Fri Jan 03, 2020 7:40 pm
No. Install it on your PC/laptop etc.
Mɐʇʇ
Re: Camshaft Timing
Post by Mɐʇʇ » Fri Jan 03, 2020 7:43 pm
...From what I can see on this problem that affects some VAG engines (not ours AFAIK) it looks like the group 93 timing becomes progressively more negative as the chain stretches. This would imply that as the chain stretches...
Or the shoes wear. The new chain & shoes on Bank 1 have worked a treat.
It does, I had already googled it. Kurbelwinkel. What a great word.
Re: Camshaft Timing
Post by Shoppinit » Fri Jan 03, 2020 7:44 pm
Cool. I am interested then. These cumbersome VM do my head in. Haven't got a recent ETKA have you?
The 93 might be in with the ignition system / sensors instead of valve gear. Have a look for Hall sensors. If you still can't find it I'll crank up the VM and have a look for you.
Mɐʇʇ
Re: Camshaft Timing
Post by Mɐʇʇ » Fri Jan 03, 2020 7:51 pm
I just use https://ifinterface.com/page/page3.php?langid=1
It's live so gives me "real" NLA status on all the bits I want.
Re: Camshaft Timing
Post by Shoppinit » Fri Jan 03, 2020 7:55 pm
Yeah, it's clunky though.
Mɐʇʇ
Re: Camshaft Timing
Post by Mɐʇʇ » Fri Jan 03, 2020 8:09 pm
Got it. Thank you. pdf here for anyone else that finds this useful.
Hall Sensors.pdf
(275.62 KiB) Downloaded 79 times
The 93 might be in with the ignition system / sensors instead of valve gear. Have a look for Hall sensors....
Mɐʇʇ
Re: Camshaft Timing
Post by Mɐʇʇ » Sat Jan 04, 2020 8:08 pm
I reset the cambelt timing based on eyeballing the exhaust timing marks, plus locked with cam bar and crank pin in.
You can see both intake and exhaust are pretty well aligned. I primarily tried to get the exhaust aligned - think I did OK?
However, Bank 2 is still marginal. So I guess it's either the hall sensor or the cam phaser that's off - but, intake on bank 2 looks good in the pics - so maybe it's doing something when the oil pressure comes up? I dunno. Will have a look at the hall sensor later to check that's on correctly (am sure it is) and then probably put the old dephaser back in bank 2 with it's new shoes on - I've got the gasket it needs on order already.
Bank 1 Exhaust:
Bank 1 Intake:
Bank 2 Exhaust:
Bank 2 Intake:
And the new timing results:
No SAI and the water pipe mode does make it easy to work on the OS (Bank 1) though, which is good:
Mɐʇʇ
Re: Camshaft Timing
Post by Mɐʇʇ » Sun Jan 05, 2020 7:45 pm
That'll do.
Re: Camshaft Timing
Post by Shoppinit » Sun Jan 05, 2020 7:46 pm
Noice. What was it?
IchBautAuto
Re: Camshaft Timing
Post by IchBautAuto » Sun Jan 05, 2020 11:00 pm
Engine speed is different? Is this relevant? Spec calls for 730 - 790 RPM.
Mɐʇʇ
Re: Camshaft Timing
Post by Mɐʇʇ » Mon Jan 06, 2020 11:22 am
Only because the motor was not quite fully warm when I screenshotted it.
Users browsing this forum: No registered users and 132 guests
