Diffuser removal
DaytonaMatt
Diffuser removal
Post by DaytonaMatt » Thu Nov 21, 2019 1:57 pm
Anyone done it without taking the bumper off?
I can get the outer edges out but can’t budge the more central set of clips and really don’t want to force it anymore than I currently am
Any tips or photos or videos!?
morski
Re: Diffuser removal
Post by morski » Thu Nov 21, 2019 6:17 pm
Can be done 'ive heard' but really suggest you take the bumper off for a proper job and no risk of breaking any tabs especially in this colder weather
RS6 Performance Ascari blue, Carbon Ceramics, Akrapovic, H&R Anti Roll bars
dasquade
Post by dasquade » Thu Nov 21, 2019 10:13 pm
I did it on my S6 C7 once, it is doable (and i have the folded towhook). If you have a long prim tool you might be able to unclip them but like pointed out with these colder temps don't force it too much.
Haven't taken of the rs diffuser yet, but if i recall correct it is the same principle/clips, that time i fully took off the bumper...
Post by MikeFish » Fri Nov 22, 2019 2:24 am
I tired but failed. Ended up taking the bumper off; much quicker in the end than all the time I spent trying to avoid taking it off.
DaytonaMatt
Post by DaytonaMatt » Fri Nov 22, 2019 11:56 am
Got it.. in which case anyone know if there’s a guide or a sticky to taking the bumper off?
Post by MikeFish » Fri Nov 22, 2019 1:38 pm
I will have a look later. Actually I think I followed the instruction in the manual. As a quick summary from memory it goes a little something like this :
Undi the 3 torx screws at the rear of the rear wheel arch. Can do it without removing wheels. I think I found it easier to grt a ratchet in there by jacking the car up slightly.
Undo the 3 bolts at the bottom of tbe diffuser.
remove rear tail lights and pull out a plastic pin.
There is an electrical plug that needs to be unplugged if you are removing the bumper completely. It can be found in the right hand side boot cover access hatch.
Then you basically pull if from each side by the rear wheel. Once each side has popped out you can slide it out backwards.
rtd
Post by rtd » Sun Nov 24, 2019 11:42 am
You just need to ease it out applying equal force along each clip I did it a few times. No need to remove bumper.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
DaytonaMatt
Post by DaytonaMatt » Sun Nov 24, 2019 1:48 pm
But how do you mean? Are you inserting anything to pop open a clip or literally just pulling?
rtd
Post by rtd » Sun Nov 24, 2019 2:10 pm
Used a trim removal tool and then start forcing it out - you may find that small stones have got lodged inside with the clips which is a bit of a pain. It’s a two man job though.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
dasquade
Post by dasquade » Sun Nov 24, 2019 10:47 pm
Indeed use a long trim removal tool to try push the retainer clips open and sometimes it helps if you can push the diffuser clip softly while you push the entire diffuser (ideally a two men job, but i managed to do it myself alone). Again be carefull now it is cold, might want to spray some wd40 onto the clips.
DaytonaMatt
Post by DaytonaMatt » Mon Nov 25, 2019 8:30 pm
When you say push the clips softly do you mean form the other side? It’s a pretty tight fit between bumper and diffuser so not sure I can do much more than try and get a tool into the right place and pull
dasquade
Post by dasquade » Mon Nov 25, 2019 11:43 pm
No i meant from under the car...since you can't really pull the diffusor at the clip from the outside it helped me a little when i pushed the tabes of the diffusor so they come loose of the clips once they are opened. But i admite the once in the center are hard since you almost can't reach them.
DaytonaMatt
Post by DaytonaMatt » Thu Nov 28, 2019 2:18 pm
So can confirm it’s possible but it’s a total pain in the arse!
Post by MikeFish » Thu Nov 28, 2019 4:30 pm
I told you. Been where you are, tried for ages then eventually decided to remove bumper and it was much easier and took less time than all the time spent trying to do it without removing bumper.
Users browsing this forum: Bing [Bot] and 29 guests
