Engine bay error codes
hi guys,
i have been monitoring my vehicle and have noticed that couple error codes appear on the car every now and then. here is a list and i was wondering if any of you have any thoughts/suggestions what could be the cause?
ps. i recently replaced the main radiator on the car.
Address 01: Engine (BUH) Labels: Redir Fail!
Part No SW: 4F1 910 552 D HW: 4F1 907 552 A
Component: 5.0L V10/4V TFSI ª0080
Revision: F1H05--- Serial number:
Coding: 010D0003190F02B0
Shop #: WSC 66565 257 00032
VCID: 2541171FEC14DD36C75-8070
3 Faults Found:
006481 - Radiator Fan 2 (V177)
P1951 - 002 - Movement Restricted / Jammed - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 22
Reset counter: 255
Time Indication: 0
Date: 2019.10.11
Time: 09:36:39
Freeze Frame:
RPM: 1598 /min
Load: 7.8 %
Speed: 40.0 km/h
Temperature: 93.0°C
Temperature: 66.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.351 V
001683 - Fan 2 Control Circuit
P0693 - 002 - Short to GND - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2019.10.13
Time: 13:48:18
Freeze Frame:
RPM: 816 /min
Load: 22.7 %
Speed: 12.0 km/h
Temperature: 93.0°C
Temperature: 42.0°C
Voltage: 14.351 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 70.0°C
Voltage: 11.811 V
Readiness: 0000 0000
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Reset counter: 255
Time Indication: 0
Date: 2019.10.11
Time: 09:36:39
Freeze Frame:
RPM: 1598 /min
Load: 7.8 %
Speed: 40.0 km/h
Temperature: 93.0°C
Temperature: 66.0°C
Voltage: 14.351 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2019.10.13
Time: 13:48:18
Freeze Frame:
RPM: 816 /min
Load: 22.7 %
Speed: 12.0 km/h
Temperature: 93.0°C
Temperature: 42.0°C
Voltage: 14.351 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 70.0°C
Voltage: 11.811 V
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
- H&R ARBs
Re: Engine bay error codes
c3nturi0n wrote: ↑Fri Nov 01, 2019 8:31 pmhi guys,
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Reset counter: 255
Time Indication: 0
Date: 2019.10.11
Time: 09:36:39
Freeze Frame:
RPM: 1598 /min
Load: 7.8 %
Speed: 40.0 km/h
Temperature: 93.0°C
Temperature: 66.0°C
Voltage: 14.351 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2019.10.13
Time: 13:48:18
Freeze Frame:
RPM: 816 /min
Load: 22.7 %
Speed: 12.0 km/h
Temperature: 93.0°C
Temperature: 42.0°C
Voltage: 14.351 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 70.0°C
Voltage: 11.811 V
Looks to me like there's an issue with one of the radiator fans from when the new rad was installed?
That looks to cover code 1 & 2, code 3 refers to needing to scan the second ECU for faults
cheers - I'll get in touch with a garage later for them to (re)inspect.
Other than emissions related 'fault' (probably due to lack of mid/rear cat's) i do not get other any codes on Engine Bank 2.
I suppose one question from my side is if the lambda / O2 sensor is faulty or on it's way out, would it cause error listed above? And more importantly, should i be worried
Thanks!
Thanks!
- H&R ARBs
- H&R ARBs
Is it not from the fans being disconnected without the battery being disconnected first? It's linked to your work done in my eyes. I'd have the codes reset and check in a few days time that they don't come back.
I doubt that battery was disconnected. Are you suggesting that it may be worth checking the fuse/s?
FYI - I do scan the car periodically (say every 3-4 weeks) and this does indeed come up each time it's done. One other thing that I noticed is that fan is running at relatively high speed/rpm every time i start the car warm (normal operating temp).
- H&R ARBs
- H&R ARBs
Does the fan go off when you turn off the A/C?
Yes, it does
Any suggestions of what could be going wrong / what needs addressing? Assume it has very little with rad work i did recently?
- H&R ARBs
- H&R ARBs
It could be signs to the resistors on their way out. This was an issue with mk4 golfs. But it could just be normal. I think mine was always on when the A/C was on.
Cheers.
Is that resistors on the actual radiator fan i guess?
- H&R ARBs
- H&R ARBs
Users browsing this forum: Bing [Bot] and 68 guests
