Engine bay error codes
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Post by c3nturi0n » Fri Nov 01, 2019 8:31 pm
hi guys,
i have been monitoring my vehicle and have noticed that couple error codes appear on the car every now and then. here is a list and i was wondering if any of you have any thoughts/suggestions what could be the cause?
ps. i recently replaced the main radiator on the car.
Address 01: Engine (BUH) Labels: Redir Fail!
Part No SW: 4F1 910 552 D HW: 4F1 907 552 A
Component: 5.0L V10/4V TFSI ª0080
Revision: F1H05--- Serial number:
Coding: 010D0003190F02B0
Shop #: WSC 66565 257 00032
VCID: 2541171FEC14DD36C75-8070
3 Faults Found:
006481 - Radiator Fan 2 (V177)
P1951 - 002 - Movement Restricted / Jammed - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 22
Reset counter: 255
Time Indication: 0
Date: 2019.10.11
Time: 09:36:39
Freeze Frame:
RPM: 1598 /min
Load: 7.8 %
Speed: 40.0 km/h
Temperature: 93.0°C
Temperature: 66.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.351 V
001683 - Fan 2 Control Circuit
P0693 - 002 - Short to GND - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2019.10.13
Time: 13:48:18
Freeze Frame:
RPM: 816 /min
Load: 22.7 %
Speed: 12.0 km/h
Temperature: 93.0°C
Temperature: 42.0°C
Voltage: 14.351 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 70.0°C
Voltage: 11.811 V
Readiness: 0000 0000
2008 RS6 Avant (Monza Silver)
- H&R ARBs
Stiggles
Re: Engine bay error codes
Post by Stiggles » Sat Nov 02, 2019 2:25 am
hi guys,
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Reset counter: 255
Time Indication: 0
Date: 2019.10.11
Time: 09:36:39
Freeze Frame:
RPM: 1598 /min
Load: 7.8 %
Speed: 40.0 km/h
Temperature: 93.0°C
Temperature: 66.0°C
Voltage: 14.351 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2019.10.13
Time: 13:48:18
Freeze Frame:
RPM: 816 /min
Load: 22.7 %
Speed: 12.0 km/h
Temperature: 93.0°C
Temperature: 42.0°C
Voltage: 14.351 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 70.0°C
Voltage: 11.811 V
Looks to me like there's an issue with one of the radiator fans from when the new rad was installed?
That looks to cover code 1 & 2, code 3 refers to needing to scan the second ECU for faults
c3nturi0n
Post by c3nturi0n » Mon Nov 04, 2019 12:38 pm
cheers - I'll get in touch with a garage later for them to (re)inspect.
Other than emissions related 'fault' (probably due to lack of mid/rear cat's) i do not get other any codes on Engine Bank 2.
I suppose one question from my side is if the lambda / O2 sensor is faulty or on it's way out, would it cause error listed above? And more importantly, should i be worried :(?
Thanks!
- H&R ARBs
Toady1
Post by Toady1 » Mon Nov 04, 2019 10:57 pm
Is it not from the fans being disconnected without the battery being disconnected first? It's linked to your work done in my eyes. I'd have the codes reset and check in a few days time that they don't come back.
c3nturi0n
Post by c3nturi0n » Tue Nov 05, 2019 2:39 pm
I doubt that battery was disconnected. Are you suggesting that it may be worth checking the fuse/s?
FYI - I do scan the car periodically (say every 3-4 weeks) and this does indeed come up each time it's done. One other thing that I noticed is that fan is running at relatively high speed/rpm every time i start the car warm (normal operating temp).
- H&R ARBs
Toady1
Post by Toady1 » Tue Nov 05, 2019 10:02 pm
Does the fan go off when you turn off the A/C?
c3nturi0n
Post by c3nturi0n » Wed Nov 06, 2019 12:29 pm
Yes, it does :roll:.
Any suggestions of what could be going wrong / what needs addressing? Assume it has very little with rad work i did recently?
- H&R ARBs
Toady1
Post by Toady1 » Wed Nov 06, 2019 8:28 pm
It could be signs to the resistors on their way out. This was an issue with mk4 golfs. But it could just be normal. I think mine was always on when the A/C was on.
c3nturi0n
Post by c3nturi0n » Wed Nov 06, 2019 9:28 pm
Cheers.
Is that resistors on the actual radiator fan i guess?
- H&R ARBs
