Wheel spacer pics
Foxmeister
Wheel spacer pics
Does anybody have any pics of their car with 10mm spacers to see how it sits? Some angles would be good
Also, what spacers are best to use and where from?
Foxmeister
Re: Wheel spacer pics
Nobody??? Anybody???
Please, dont make me beg...
Beg, biatch.
You could use the search function, there have been loads of pics put up on the C5 forum. Hopefully not all of them have been done over by photofucket
10mm H and R hubcentric.
I'll try and get a few pics......
A few that I was able to pull quickly.
Foxmeister
Foxmeister
Chunky, pretty much any forum search function is a load of pish so i never bothered with it, tried Pinterest, Google etc but theres a severe lack of decent C5 pics with info, we're being over run with these C7 beasts it seems, but i'll have a look
Foxmeister
Well played sir
From what i gather, 10mm is the max for the C5 but it looks like it could maybe do a bit more, wonder if 12mm would fit ok
The search function on here had always been pretty good imo.
Think you may get some rubbing with 12mm, and possibly be outside the arches. Also got to be careful with wheel bolt length.
Foxmeister
Ok, i'll stick with the 10mm likely as they look fine and will just be a second set of wheels as i will be fitting the 20's soon
I did see something about the bolts, do you get replacement bolts with the spacers, no?
Not sure mate, I don't run spacers. Folk used to get them from Virdee, not sure of he still sells them.
H&R you get the bolts with them so no worries about that.
99% of the time I don't get rubbing. I do however get occasional rubs when hitting a dip in the road at speed but it appears to be more the lower edge of the wheel by the back door/sill area rather than the upper arch. Might be something to do with my camber set up.
I run KW V3 on mine, but have no idea of the settings. It was all done when I bought the car and I can see nothing in the paperwork with regard to settings other than... "Fitted"
Foxmeister
Cheers Chunk, i'll see what he says
Nice one Mark, i had been looking at Eibach but i'll have a look at the H&R alsoMark-RS wrote: ↑Thu Oct 10, 2019 3:48 pmH&R you get the bolts with them so no worries about that.
It looks good sitting low, just not sure if i can get away with it myself
Here is mine on Bilsteins and 10mm H&R spacers (if the upload works)
Sent from my VOG-L29 using Tapatalk
Users browsing this forum: No registered users and 143 guests
