Wheel spacer pics
Foxmeister
Wheel spacer pics
Post by Foxmeister » Tue Oct 08, 2019 6:11 am
Does anybody have any pics of their car with 10mm spacers to see how it sits? Some angles would be good
Also, what spacers are best to use and where from?
Foxmeister
Re: Wheel spacer pics
Post by Foxmeister » Wed Oct 09, 2019 5:33 am
Nobody??? Anybody???
Please, dont make me beg...
Post by Shoppinit » Wed Oct 09, 2019 11:01 am
Beg, biatch.
Post by chunky79 » Wed Oct 09, 2019 1:06 pm
You could use the search function, there have been loads of pics put up on the C5 forum. Hopefully not all of them have been done over by photofucket
Mark-RS
Post by Mark-RS » Wed Oct 09, 2019 4:09 pm
10mm H and R hubcentric.
I'll try and get a few pics......
Mark-RS
Post by Mark-RS » Wed Oct 09, 2019 4:30 pm
A few that I was able to pull quickly.
Foxmeister
Post by Foxmeister » Thu Oct 10, 2019 3:33 am
Beg, biatch.
Ok Mr Shopp... do i have to gargle also? :shock:
Foxmeister
Post by Foxmeister » Thu Oct 10, 2019 3:39 am
Chunky, pretty much any forum search function is a load of pish so i never bothered with it, tried Pinterest, Google etc but theres a severe lack of decent C5 pics with info, we're being over run with these C7 beasts it seems, but i'll have a look :bigblink:
Foxmeister
Post by Foxmeister » Thu Oct 10, 2019 3:53 am
Well played sir :thumb: that looks great, and quite low, what suspension you got? Does it rub at all with the spacers?
From what i gather, 10mm is the max for the C5 but it looks like it could maybe do a bit more, wonder if 12mm would fit ok
Post by chunky79 » Thu Oct 10, 2019 11:19 am
The search function on here had always been pretty good imo.
Think you may get some rubbing with 12mm, and possibly be outside the arches. Also got to be careful with wheel bolt length.
Foxmeister
Post by Foxmeister » Thu Oct 10, 2019 12:41 pm
Ok, i'll stick with the 10mm likely as they look fine and will just be a second set of wheels as i will be fitting the 20's soon
I did see something about the bolts, do you get replacement bolts with the spacers, no?
Post by chunky79 » Thu Oct 10, 2019 1:08 pm
Not sure mate, I don't run spacers. Folk used to get them from Virdee, not sure of he still sells them.
Mark-RS
Post by Mark-RS » Thu Oct 10, 2019 3:48 pm
H&R you get the bolts with them so no worries about that.
99% of the time I don't get rubbing. I do however get occasional rubs when hitting a dip in the road at speed but it appears to be more the lower edge of the wheel by the back door/sill area rather than the upper arch. Might be something to do with my camber set up.
I run KW V3 on mine, but have no idea of the settings. It was all done when I bought the car and I can see nothing in the paperwork with regard to settings other than... "Fitted"
Foxmeister
Post by Foxmeister » Fri Oct 11, 2019 3:17 am
Cheers Chunk, i'll see what he says :thumbs:
Nice one Mark, i had been looking at Eibach but i'll have a look at the H&R also
It looks good sitting low, just not sure if i can get away with it myself :thumb:
V!per
Post by V!per » Thu Oct 17, 2019 5:57 pm
Here is mine on Bilsteins and 10mm H&R spacers (if the upload works) ImageImageImageImage
Sent from my VOG-L29 using Tapatalk
Users browsing this forum: No registered users and 159 guests
