Vag-Com cable
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
mikeyquattro
Vag-Com cable
Post by mikeyquattro » Sat Jan 07, 2006 10:21 am
Can anyone tell me which Vag-com cable i need? :?
(prefer an ebay item)
I have both serial and usb ports.
Mike
Tomorrow is another day
philipwalker
RE: Vag-Com cable
Post by philipwalker » Sat Jan 07, 2006 10:25 am
Some of the "ebay items" give a very limited vag com use.
Sure someone will explain why??
The proper vag com lead from Ross tech is prefered, dont think they cost that much either.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
CliveH
RE: Vag-Com cable
Post by CliveH » Sat Jan 07, 2006 10:49 am
Clive
fade2grey
RE: Vag-Com cable
Post by fade2grey » Sat Jan 07, 2006 2:55 pm
I've got a USB hexcom straight from ross-tech - just buy it direct, they are easy to deal with & put a lot of effort into it.
98/Missano/Bose/Carbon
CliveH
RE: Vag-Com cable
Post by CliveH » Sat Jan 07, 2006 4:20 pm
I agree - support Rosstech - that way they will continue to produce great products.
Be nice if we could say the same about Misocroft!!! :assflash:
Clive
KayGee
RE: Vag-Com cable
Post by KayGee » Sun Jan 08, 2006 3:23 am
Ebay cables will allow limited use of 3.11.2, this is an old version of VAGCom. Rosstech or approved distributor cables are dearer but instantly recognize later version of software. What does this mean....
1. Flash updating of interfaces as issues are fixed as you use later versions of the software.
2. Continued support for VagCom. Ebay guys pay nothing toward RossTech running costs.
3. Latest and greatest features for VAGCom, like can bus support etc....
http://www.ross-tech.com/vag-com/revisions.html
4. Advanced feature set.
http://www.ross-tech.com/vag-com/vag-functions.html
5. Activate the older VAGCom version costs $99 + ebay costs and is fixed to that PC. RossTech Key or Hex cables are transportable and start at $229. Download software run it, plug in cable and your are good to go on any PC capable of running the SW.
6. They wrote VAGCom, without Uwe and the RossTech teams dedication we wouldn't have the software available.
7. Tech support is awesome.
Hope that helps.
confusionhunter
RE: Vag-Com cable
Post by confusionhunter » Sun Jan 08, 2006 12:37 pm
And lastly, the ebay ones dont fit in the plugs in the A4's with the plug in the rear ash tray as the trim around it is too tight.... I have an ebay one and its cack(£30 if you want it... lol)..... Ive ordered a KEY-USB cable from ross tech last week....
Mark.
mikeyquattro
RE: Vag-Com cable
Post by mikeyquattro » Sun Jan 08, 2006 2:01 pm
Give you a tenner for it!! :wink:
confusionhunter
RE: Vag-Com cable
Post by confusionhunter » Sun Jan 08, 2006 8:19 pm
maybe..... I'll see if I can peddle it on some VW sites where it might be of some use to people first!
Mark.
Return to “DTC / VCDS”
Users browsing this forum: Google Adsense [Bot] and 31 guests
