Does anyone get this when they scan for faults.
Address 25: Immobilizer
Controller: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
I have always had the same message and was wondering if it is common or if i have a comunication problem with the controller.
VAGCOM
- SimonS4MTM
- Top Gear
VAGCOM
- ChipHazzard
RE: VAGCOM
I had the same code on mine and from memory it hasnt come back since i cleared it. I'll try and remember to run a scan tonight
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
RE: VAGCOM
This means that the immobiliser is not at address 25 (which was used on older cars) but at address 17, which is the instruments cluster.
HTH,
Mihnea
HTH,
Mihnea
- gavsteryoung
RE: VAGCOM
Simon, I get the same......
Could be something to do with the presets on the VAGCOM when picking B5 A4. I have often thought about getting it to scan every address possible.....
09 Audi S3 - Sprint Blue
99 Audi S4 - Ming Blue - (Gone but not forgotten)
04 Vauxhall Tigra 1.8 Sport - Antiga Blue (The Mrs Car)
RE: VAGCOM
If I remember correctly you can "fix" that in the label file. Sure it is on the vagcom forum somewhere.
