VAGCOM
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
SimonS4MTM
VAGCOM
Post by SimonS4MTM » Wed Dec 14, 2005 2:51 pm
Does anyone get this when they scan for faults.
Address 25: Immobilizer
Controller: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
I have always had the same message and was wondering if it is common or if i have a comunication problem with the controller.
ChipHazzard
RE: VAGCOM
Post by ChipHazzard » Wed Dec 14, 2005 3:02 pm
I had the same code on mine and from memory it hasnt come back since i cleared it. I'll try and remember to run a scan tonight
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
S2tuner
Trader (Expired)
RE: VAGCOM
Post by S2tuner » Wed Dec 14, 2005 3:13 pm
This means that the immobiliser is not at address 25 (which was used on older cars) but at address 17, which is the instruments cluster.
HTH,
Mihnea
gavsteryoung
RE: VAGCOM
Post by gavsteryoung » Wed Dec 14, 2005 3:22 pm
Simon, I get the same......
Could be something to do with the presets on the VAGCOM when picking B5 A4. I have often thought about getting it to scan every address possible.....
09 Audi S3 - Sprint Blue
99 Audi S4 - Ming Blue - (Gone but not forgotten)
04 Vauxhall Tigra 1.8 Sport - Antiga Blue (The Mrs Car)
KayGee
RE: VAGCOM
Post by KayGee » Wed Dec 14, 2005 7:32 pm
If I remember correctly you can "fix" that in the label file. Sure it is on the vagcom forum somewhere.
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 39 guests
