Rear Callipers upgrade
I’m looking to replace my rear callipers for some tarox
I’ve had a good look around but cannot find anyone that has done this ?
Do tarox even supply a calliper for the rear
Main reason mine are showing there age plus I’ve tarox up front so would like them to match
I have emailed tarox twice now with no reply
Any suggestions or links would be appreciated
Re: Rear Callipers upgrade
Reply from tarox
Hi Andy
The issue with the rear set up is the integral handbrake caliper. Systems can be built but they are not off the shelf. Some of dealers build kit by retaining the OE caliper for the handbrake and then building a bracket to mount our calipers.
If you are happy for someone to start a project like this then I would recommend. TSR, VRT or Retro Resus as they all have experience with custom rear kits.
Hi Andy
So you going for it then?
Didn't Jonytek do a custom ceramic rear setup with seperate handbrake caliper? Where is he? Haven't seen him on here or insta for a while!
- Surrey Sam
Yes mike it’s always bugged me on my last one with ceramics and steel miss match now on the new oneMikeFish wrote:So you going for it then?
I’ve the discs to match but the rear callipers are showing there age so I’m looking to swap them
Thanks Sam I’ll look into that option
Also the r8 rears but I’ll have to get the colour matched to my fronts
Someone has mentioned jony tec before I’ll try contact him for some advice
I wonder if https://www.tomwrigleyperformance.com/ could help. Not sure if it’s only AP they do though.
andyg72 wrote:Someone has mentioned jony tec before I’ll try contact him for some advice
Jonys RS4 Project
https://r.tapatalk.com/shareLink?share_ ... are_type=t
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Seems all modifications on the rears require separate handbrake & messes with the brake bias if this is the case I’ll not Pursue & most likely replace with stock callipers but colour match to the fronts either anodise or powder coat
Definitely the easiest job. Get them re powder coated and refurb them whilst they are out.andyg72 wrote:Seems all modifications on the rears require separate handbrake & messes with the brake bias if this is the case I’ll not Pursue & most likely replace with stock callipers but colour match to the fronts either anodise or powder coat
I did the refurb myself and just had them powder coated by someone else.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Jon do you know if they Can be anodised ?Jon_J wrote:Definitely the easiest job. Get them re powder coated and refurb them whilst they are out.andyg72 wrote:Seems all modifications on the rears require separate handbrake & messes with the brake bias if this is the case I’ll not Pursue & most likely replace with stock callipers but colour match to the fronts either anodise or powder coat
Iill buy new so straight swap once colour has been sorted
They are aluminium so don’t see why not?andyg72 wrote:Jon do you know if they Can be anodised ?Jon_J wrote:Definitely the easiest job. Get them re powder coated and refurb them whilst they are out.andyg72 wrote:Seems all modifications on the rears require separate handbrake & messes with the brake bias if this is the case I’ll not Pursue & most likely replace with stock callipers but colour match to the fronts either anodise or powder coat
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
I wasn’t sure if they were alloy now I know
Definitely alloyandyg72 wrote:I wasn’t sure if they were alloy now I know
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Users browsing this forum: Google Adsense [Bot] and 284 guests
