Rear Callipers upgrade
andyg72
Post by andyg72 » Mon Nov 12, 2018 2:38 pm
I’m looking to replace my rear callipers for some tarox
I’ve had a good look around but cannot find anyone that has done this ?
Do tarox even supply a calliper for the rear
Main reason mine are showing there age plus I’ve tarox up front so would like them to match
I have emailed tarox twice now with no reply
Any suggestions or links would be appreciated
andyg72
Re: Rear Callipers upgrade
Post by andyg72 » Mon Nov 12, 2018 4:16 pm
Reply from tarox
Hi Andy
The issue with the rear set up is the integral handbrake caliper. Systems can be built but they are not off the shelf. Some of dealers build kit by retaining the OE caliper for the handbrake and then building a bracket to mount our calipers.
If you are happy for someone to start a project like this then I would recommend. TSR, VRT or Retro Resus as they all have experience with custom rear kits.
Post by MikeFish » Mon Nov 12, 2018 7:21 pm
So you going for it then?
Didn't Jonytek do a custom ceramic rear setup with seperate handbrake caliper? Where is he? Haven't seen him on here or insta for a while!
Surrey Sam
Post by Surrey Sam » Mon Nov 12, 2018 7:29 pm
Movit did/do a kit for the B7 - http://www.movitcars.com/rahmen/audi.htm
andyg72
Post by andyg72 » Mon Nov 12, 2018 8:30 pm
MikeFish wrote:So you going for it then?
Yes mike it’s always bugged me on my last one with ceramics and steel miss match now on the new one
I’ve the discs to match but the rear callipers are showing there age so I’m looking to swap them
andyg72
Post by andyg72 » Mon Nov 12, 2018 8:31 pm
Surrey Sam wrote:Movit did/do a kit for the B7 - http://www.movitcars.com/rahmen/audi.htm
Thanks Sam I’ll look into that option
Also the r8 rears but I’ll have to get the colour matched to my fronts
andyg72
Post by andyg72 » Mon Nov 12, 2018 8:35 pm
Someone has mentioned jony tec before I’ll try contact him for some advice
marc1
Post by marc1 » Mon Nov 12, 2018 9:47 pm
I wonder if https://www.tomwrigleyperformance.com/ could help. Not sure if it’s only AP they do though.
Jon_J
Post by Jon_J » Mon Nov 12, 2018 11:30 pm
andyg72 wrote:Someone has mentioned jony tec before I’ll try contact him for some advice
Jonys RS4 Project
https://r.tapatalk.com/shareLink?share_ ... are_type=t
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
andyg72
Post by andyg72 » Mon Nov 12, 2018 11:32 pm
Seems all modifications on the rears require separate handbrake & messes with the brake bias if this is the case I’ll not Pursue & most likely replace with stock callipers but colour match to the fronts either anodise or powder coat
Jon_J
Post by Jon_J » Mon Nov 12, 2018 11:34 pm
andyg72 wrote:Seems all modifications on the rears require separate handbrake & messes with the brake bias if this is the case I’ll not Pursue & most likely replace with stock callipers but colour match to the fronts either anodise or powder coat
Definitely the easiest job. Get them re powder coated and refurb them whilst they are out.
I did the refurb myself and just had them powder coated by someone else.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
andyg72
Post by andyg72 » Mon Nov 12, 2018 11:37 pm
Jon do you know if they Can be anodised ?
Iill buy new so straight swap once colour has been sorted
Jon_J
Post by Jon_J » Mon Nov 12, 2018 11:39 pm
They are aluminium so don’t see why not?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
andyg72
Post by andyg72 » Tue Nov 13, 2018 12:18 am
I wasn’t sure if they were alloy now I know :)
Jon_J
Post by Jon_J » Tue Nov 13, 2018 7:50 am
andyg72 wrote:I wasn’t sure if they were alloy now I know :)
Definitely alloy
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Users browsing this forum: Google Adsense [Bot] and 282 guests
