The coolant pipes
5.0 V10 50v biturbo - 571 bhp
Doug_RS6
The coolant pipes
Post by Doug_RS6 » Fri Oct 12, 2018 4:14 pm
Noticed that my coolant pipes aren't looking too clever. Only under the bracket. Rest looks remarkably good. Is there anything really against cutting out the sections and putting rubber lines in? Don't suppose anyone has the diameters to hand?
Woodygo
Re: The coolant pipes
Post by Woodygo » Fri Oct 12, 2018 4:47 pm
Hi I have just done mine I can send you photos they are on here but I will repost them and if you need to speak to me pm me and I can send you my number if that helps you out thanks Steve
Rs6 c6 Daytona gray (sold)
Rs6 c5 silver (sold)
Seat Cupra mk3 pocket rocket (370bhp)
Woodygo
Post by Woodygo » Fri Oct 12, 2018 4:50 pm
Photos jobs a good one lol
Doug_RS6
Post by Doug_RS6 » Fri Oct 12, 2018 5:15 pm
That is excellent mate. Why did you remove such big sections though? On mine anyway it's litterally about 3 inches of each pipe needing replaced. So wasn't even going to bother giving Audi the parts money. Was just going to cut and replace the rotten part with rubber hose.
What diameter did you need to join the pipes? It's about £200 for the pipes isn't it?
Doug_RS6
Post by Doug_RS6 » Fri Oct 12, 2018 5:18 pm
Oh and what did you need to remove for access? One pipe is fairly easy to replace I gather?
Woodygo
Post by Woodygo » Fri Oct 12, 2018 5:57 pm
Trade is £171 and £41 plus vat
Doug_RS6
Post by Doug_RS6 » Fri Oct 12, 2018 5:59 pm
Thanks. What diameter of rubber hose did you use for them? I take it the £171 is the longer one that you cut?
Woodygo
Post by Woodygo » Fri Oct 12, 2018 6:32 pm
Yeah and cut it by where it go’ Under steering rack I have the rubber pipe I used in my other shed I will go and the size pipe I used to connect the two pipes together
Doug_RS6
Post by Doug_RS6 » Fri Oct 12, 2018 6:37 pm
Excellent mate. Appreciate that. Just so I can order the house now before I poke a hole in it.
Woodygo
Post by Woodygo » Fri Oct 12, 2018 6:39 pm
Inner 16mm
Woodygo
Post by Woodygo » Fri Oct 12, 2018 6:40 pm
Are you going to the Audi drivers international tomorrow if so I can brin you the length I have save you buying any mate
Doug_RS6
Post by Doug_RS6 » Fri Oct 12, 2018 6:49 pm
Perfect mate. 16mm inner for both. That's very kind of you. Unfortunately I'm working tomorrow all day. I didn't even know there was an event on if I'm honest. New to the whole VAG scene. Most of the stuff I've bought in the past is too obscure for any kind of meet to be organised.
Woodygo
Post by Woodygo » Fri Oct 12, 2018 6:55 pm
My first meet too I have always had fast ish cars this is my second rs6 I have had c5 and c6 if I can help in anyway private message me with your number or I can text you mine what part of uk are you
Woodygo
Post by Woodygo » Fri Oct 12, 2018 8:23 pm
Hi mate if you was local I would of help you do it but your a little bit to far for me lol
Woodygo
Post by Woodygo » Fri Oct 12, 2018 8:24 pm
Got your message I will try and call you tomorrow in the day and try and explain how it goes 👍
