Now onto the planetary sun gear assembly; remove the flange washer from the top of the inner gear
Followed by the gear itself (ZF also have a tool for removing these gears, but its easy to do by hand
Now with the aid of a small pick unclip the central needle bearing and inspect it, again this one was good
Now the observant ones out there will notice this box is full all of a sudden,its just the way the pics come out guys, there's nothing hidden in there; we will get to it all at some point!
Now remove the lower gear, again its easy enough with fingers with a little tension and twisting motion
Now notice this also has a needle bearing on the bottom face which is exactly the same size; if you are renewing these it doesnt matter which one goes where, but if you are reusing its wise to keep them where they came from as the wear faces will then match. To this end I identify the bottom one by putting it in a plastic food bag, simples
