Radio and Lights Issue
EireRS6
Post by EireRS6 » Thu Jul 12, 2018 11:35 am
Hello there,
I have an issue at the moment where my radio won't turn off when I remove the key so I have to switch it off on the button each time I turn the car off.
Also, if I turn the car off leaving the lights on, there is no beep or warning sound. I'm assuming there should be?
Can anyone help with the above? Are the issues linked in any way?
Re: Radio and Lights Issue
Post by Shoppinit » Thu Jul 12, 2018 11:36 am
Sounds like the key-in switch is borked on your ignition switch.
MeTsU
Post by MeTsU » Thu Jul 12, 2018 11:42 am
Odd question, but if you accidentally leave your handbrake up, does the car beep at you? Come to think of it, I'm not sure if the handbrake uses the same buzzer or not.
2004 Audi RS6 Avant Plus #283
EireRS6
Post by EireRS6 » Thu Jul 12, 2018 11:50 am
So I just need to replace the ignition switch?
EireRS6
No, I've never noticed this happen.
Post by Shoppinit » Thu Jul 12, 2018 11:53 am
You can probably test it with the Vagcom.
EireRS6
Post by EireRS6 » Thu Jul 12, 2018 11:54 am
Ok. One really needs to have Vagcom with these machines!
Post by Shoppinit » Thu Jul 12, 2018 12:12 pm
It's the first tool any owner should buy.
EireRS6
Post by EireRS6 » Thu Jul 12, 2018 1:03 pm
Do they ever come up for sale on here?
Seems to be loads of types available. Is there any you would recommend?
MeTsU
Post by MeTsU » Thu Jul 12, 2018 1:07 pm
I have the 2017 version of the VCDS cable which is unlimited VINs. Reference to https://store.ross-tech.com/shop/vchv2_ent/
I'm not sure who the Distributors are in the UK, but locally in ZA, https://shop.hexdiagnostics.co.za/produ ... 2amqk21c63 is what I have.
EireRS6
Post by EireRS6 » Thu Jul 12, 2018 1:12 pm
Thanks MeTsU.
Post by Shoppinit » Thu Jul 12, 2018 1:26 pm
Try ilexa.co.uk or Gendan.
My OCD means I must own unlimited versions. :-/
EireRS6
Post by EireRS6 » Thu Jul 12, 2018 2:36 pm
There looks to be a 3 VIN from Gendan for £225.
Mark-RS
Post by Mark-RS » Thu Jul 12, 2018 4:25 pm
My cheap eBay cable works just fine :-)
Mɐʇʇ
Post by Mɐʇʇ » Thu Jul 12, 2018 5:10 pm
Well, 2nd. First is an extra large pot of vaseline.
Users browsing this forum: Google [Bot] and 195 guests
