Radio and Lights Issue
Hello there,
I have an issue at the moment where my radio won't turn off when I remove the key so I have to switch it off on the button each time I turn the car off.
Also, if I turn the car off leaving the lights on, there is no beep or warning sound. I'm assuming there should be?
Can anyone help with the above? Are the issues linked in any way?
Re: Radio and Lights Issue
Sounds like the key-in switch is borked on your ignition switch.
Odd question, but if you accidentally leave your handbrake up, does the car beep at you? Come to think of it, I'm not sure if the handbrake uses the same buzzer or not.
2004 Audi RS6 Avant Plus #283
You can probably test it with the Vagcom.
Ok. One really needs to have Vagcom with these machines!
It's the first tool any owner should buy.
Do they ever come up for sale on here?
Seems to be loads of types available. Is there any you would recommend?
I have the 2017 version of the VCDS cable which is unlimited VINs. Reference to https://store.ross-tech.com/shop/vchv2_ent/
I'm not sure who the Distributors are in the UK, but locally in ZA, https://shop.hexdiagnostics.co.za/produ ... 2amqk21c63 is what I have.
Thanks MeTsU.
Try ilexa.co.uk or Gendan.
My OCD means I must own unlimited versions. :-/
There looks to be a 3 VIN from Gendan for £225.
My cheap eBay cable works just fine
Users browsing this forum: Google [Bot] and 367 guests
