Which brakepad manufacturer
5.0 V10 50v biturbo - 571 bhp
rs6danbar
Post by rs6danbar » Fri Jun 29, 2018 8:55 am
Looking for new brakepads for my RS6.
Which brands are good, and what are the exact dimensions for the front brakepads?
I get alot of diffrent options but the most common is: 189,3, 93,1, 16,6.
And can you change the rear brakepads by yourself? thinking of the electronic parkingbrake.
:jump_clap: :blackrs4:
grahamh84
Re: Which brakepad manufacturer
Post by grahamh84 » Fri Jun 29, 2018 9:03 am
AP’s Disc’s and Ferodo DS2500 pads great for odd track day. I bought mine from clarkmotorsport.co.uk
rs6danbar
Post by rs6danbar » Fri Jun 29, 2018 9:11 am
What you paid for those?
Im in sweden so i' guess i'll be charged for shipping aswell :)
grahamh84
Post by grahamh84 » Fri Jun 29, 2018 10:43 am
Pads
Mounting Bells
AP Disks
Total was £1,670.58
Jim Haseltine
Post by Jim Haseltine » Fri Jun 29, 2018 12:40 pm
With the exception of disconnecting the pad wear sensors, with a couple of correct sized punches and a pad spreader tool changing the fronts is probably the simplest brake job I've done in a long time. There's a lot of conflicting advice on the net but it looks like without access to software to retract and reset the handbrake the rears are not a job you can properly do yourself.
don0301
Post by don0301 » Fri Jun 29, 2018 1:33 pm
Isn't it just a setting in the MMI for the rear parking brake/rear maintenance?
Or am I thinking about the park for the wiper blades?
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah :shock:
douglas96
Post by douglas96 » Fri Jun 29, 2018 3:17 pm
I agree with Jim - the front brakes are very easy to change. If you're just changing the pads, you don't even need to remove the caliper. Again as Jim says though, you do need a good pad spreader for both the front and rears.
The rears require access to VCDS or similar to retract the EPB. If you do this, VCDS have a video on YouTube explaining how. It mentions that it is imperative to have a power supply connected to the charging points when putting the EPB into service mode; I have a CTEK MXS10 for this purpose as it has the trickle charge function and a power supply function.
Don - you're thinking of the wipers. That would be a good feature though!
rs6danbar
Post by rs6danbar » Fri Jun 29, 2018 4:16 pm
My wireing to the sensors are bad so i disconnected them for good by connecting +/-.
I'll do the front by myself and let my lokal mechanic do the rear, thanks for the answres!
don0301
Post by don0301 » Fri Jun 29, 2018 4:18 pm
Ah yeah, I've got VCDS so that must be where I saw something about it.
Cheers.
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
ATinOf
Post by ATinOf » Tue Jul 10, 2018 11:43 am
You guys know if there's a block I can interrogate in VCDS to tell me which pads are running low I've go the warning light up on the dash (yeah I know how lazy of me why don't I whip the wheels off and check.... Its too hot!)
douglas96
Post by douglas96 » Tue Jul 10, 2018 10:24 pm
Hi,
The rear pads don't have wear sensors fitted so the warning is for the fronts. Some rear pads have a metal plate inside the friction material that makes a noise when they wear down. I don't know whether our rear brake pads have that or not.
ATinOf
Post by ATinOf » Wed Jul 11, 2018 8:51 pm
Every day is a school day ! Thanks I'll get some on order for the weekend
ATinOf
Post by ATinOf » Sat Jul 14, 2018 10:22 pm
I agree with Jim - the front brakes are very easy to change. If you're just changing the pads, you don't even need to remove the caliper. Again as Jim says though, you do need a good pad spreader ...
Doesn't the universal pad spreader tooling work on these calipers then (Oversize flat-head screwdrever / prybar / or if caliper is off G-Clamp)?? If I need a pad spreader when I do my fronts shortly I'm going to come unstuck....
Jim Haseltine
Post by Jim Haseltine » Sun Jul 15, 2018 9:24 am
This sort of thing will do it.(Other sources are available).
douglas96
Post by douglas96 » Mon Jul 16, 2018 9:23 am
You'd *probably* get away with it, but I wouldn't recommend using g-clamps for a couple of reasons;
1. They'll mark the painted finish of the caliper (Although a rag between the faces would stop that)
2. Because they have 3 pistons each side, as you start to push one side back in, the other side will start going out. Also, if you push them individually, then the others will start to go out. It's like a game of whack a mole!
But I would definitely say get a pad spreader, it makes it a lot easier in the long run.
I ordered from my Snap On rep part number BTCP2S which is an excellent tool, but it took 3 months for it to arrive as it had to come direct from the U.S. as there was none in Britain.
(Sorry for the delayed reply, I've been quite busy the last couple of days).
Users browsing this forum: Google Adsense [Bot], Jim Haseltine and 55 guests
