Adaptive cruise
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Adaptive cruise
Post by c3nturi0n » Thu Jul 05, 2018 4:11 pm
I had a quick drive around last night and noticed that ACC on the car popped up with "Acc not available"... I did quick scan on VCDS which resulted in following.
Any thoughts or suggestions?
00234 - Sensor for Automatic Distance Regulation Misadjusted
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 216
Time Indication: 0
Date: 2018.06.09
Time: 22:53:08
Freeze Frame:
Temperature: 27.0°C
Voltage: 14.08 V
Bin. Bits: 00010
Hex Value: 0x2AE1
Hex Value: 0x0003
Speed: 126.0 km/h
Lateral Accel.: -0.12 m/s^2
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
Jim Haseltine
Re: Adaptive cruise
Post by Jim Haseltine » Thu Jul 05, 2018 4:45 pm
Try cleaning the lens behind the radiator grille. Sometimes that's all it needs.
c3nturi0n
Re: Adaptive cruise
Post by c3nturi0n » Fri Jul 06, 2018 10:07 am
thx Jim... I hope it's not bumper off job?
- H&R ARBs
Jim Haseltine
Re: Adaptive cruise
Post by Jim Haseltine » Fri Jul 06, 2018 5:07 pm
Pass. I'd suspect that you'd be able to get to it either from above with the bonnet latch cover removed of from below with the under engine panel off.
Stiggles
Re: Adaptive cruise
Post by Stiggles » Sat Jul 07, 2018 12:24 am
You may also want to check the lense cover is not damaged, I recall this was the reason for mine giving an acc error.
c3nturi0n
Re: Adaptive cruise
Post by c3nturi0n » Sat Jul 07, 2018 6:20 pm
Cannot get the damn acc cover off - grrr... i noticed that i have loose connecter but nowhere to plug :-).
Any hints?
- H&R ARBs
c3nturi0n
Re: Adaptive cruise
Post by c3nturi0n » Sat Jul 07, 2018 6:35 pm
With image
- H&R ARBs
c3nturi0n
Re: Adaptive cruise
Post by c3nturi0n » Mon Jul 09, 2018 12:02 pm
any thoughts or suggestions?
- H&R ARBs
Stiggles
Re: Adaptive cruise
Post by Stiggles » Wed Jul 11, 2018 9:58 pm
As luck would have it Audi accidentally ordered the radar plate when I asked for just the grill. So I can shed a little light on your cable. It's attached to the plate, what it's for I am unsure but would imagine it's related to the heating of the plate or something?
So get the car on a lift or squeeze under it and try to figure out the location for the plug. Probably quite close as the cable isn't very long.
Tried uploading a picture but can't directly to the site
https://drive.google.com/file/d/1i_1Xqs ... p=drivesdk
https://drive.google.com/file/d/18NifpW ... p=drivesdk
Users browsing this forum: French, Google Adsense [Bot] and 345 guests
