Adaptive cruise
Adaptive cruise
I had a quick drive around last night and noticed that ACC on the car popped up with "Acc not available"... I did quick scan on VCDS which resulted in following.
Any thoughts or suggestions?
00234 - Sensor for Automatic Distance Regulation Misadjusted
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 216
Time Indication: 0
Date: 2018.06.09
Time: 22:53:08
Freeze Frame:
Temperature: 27.0°C
Voltage: 14.08 V
Bin. Bits: 00010
Hex Value: 0x2AE1
Hex Value: 0x0003
Speed: 126.0 km/h
Lateral Accel.: -0.12 m/s^2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 216
Time Indication: 0
Date: 2018.06.09
Time: 22:53:08
Freeze Frame:
Temperature: 27.0°C
Voltage: 14.08 V
Bin. Bits: 00010
Hex Value: 0x2AE1
Hex Value: 0x0003
Speed: 126.0 km/h
2008 RS6 Avant (Monza Silver)
- H&R ARBs
- H&R ARBs
Jim Haseltine
Re: Adaptive cruise
Try cleaning the lens behind the radiator grille. Sometimes that's all it needs.
Re: Adaptive cruise
thx Jim... I hope it's not bumper off job?
- H&R ARBs
- H&R ARBs
Jim Haseltine
Re: Adaptive cruise
Pass. I'd suspect that you'd be able to get to it either from above with the bonnet latch cover removed of from below with the under engine panel off.
Re: Adaptive cruise
You may also want to check the lense cover is not damaged, I recall this was the reason for mine giving an acc error.
Re: Adaptive cruise
Cannot get the damn acc cover off - grrr... i noticed that i have loose connecter but nowhere to plug
Any hints?
Any hints?
- H&R ARBs
- H&R ARBs
Re: Adaptive cruise
With image
- H&R ARBs
- H&R ARBs
Re: Adaptive cruise
any thoughts or suggestions?
- H&R ARBs
- H&R ARBs
Re: Adaptive cruise
As luck would have it Audi accidentally ordered the radar plate when I asked for just the grill. So I can shed a little light on your cable. It's attached to the plate, what it's for I am unsure but would imagine it's related to the heating of the plate or something?
So get the car on a lift or squeeze under it and try to figure out the location for the plug. Probably quite close as the cable isn't very long.
Tried uploading a picture but can't directly to the site
https://drive.google.com/file/d/1i_1Xqs ... p=drivesdk
https://drive.google.com/file/d/18NifpW ... p=drivesdk
Users browsing this forum: hartley1967 and 36 guests
