Reylands replacment discs
Neilb76
Post by Neilb76 » Sat Apr 28, 2018 4:47 pm
Looking like i will need some discs. Got some brake bounce coming in. Seen the discs inly for £345 or the full disc amd bell for about £600.
Seeing of anybody has juat done the disc and bolted it to your bells. Odviously with a new fitting kit as well
James1984
Re: Reylands replacment discs
Post by James1984 » Sat Apr 28, 2018 7:39 pm
Not fitted yet buts what i will be doing as soon as i give martin the dimensions for a matching rear set, indont fancy having drilled rear and grooved fronts (for aesthetics)
Neilb76
Post by Neilb76 » Sat Apr 28, 2018 9:48 pm
Thats very true will they make then groove for the rears ?
James1984
Post by James1984 » Sun Apr 29, 2018 8:36 pm
Yeah to match the front
Harris.
Post by Harris. » Wed May 09, 2018 1:07 pm
Ive just fitted the fronts Reyland discs , there excellent
marc1
Post by marc1 » Wed May 09, 2018 3:24 pm
Did you fit them to your existing bells or buy new from Reylands?
neil_f
Post by neil_f » Wed May 09, 2018 5:04 pm
Been thinking of buying these as well. Did the mounting bolts come off the old bells easily enough as mine look quite rusty?. Also is there an additional noise from the grooves. My experience of grooved discs from years ago was that they tended to give off a whirring noise .
Bladerider
Post by Bladerider » Thu May 10, 2018 12:20 am
Reyland ??
As in Martin Hadland ??
DavidRS4
Post by DavidRS4 » Thu May 10, 2018 9:07 pm
Yes
Users browsing this forum: No registered users and 81 guests
