Reylands replacment discs
Looking like i will need some discs. Got some brake bounce coming in. Seen the discs inly for £345 or the full disc amd bell for about £600.
Seeing of anybody has juat done the disc and bolted it to your bells. Odviously with a new fitting kit as well
Re: Reylands replacment discs
Not fitted yet buts what i will be doing as soon as i give martin the dimensions for a matching rear set, indont fancy having drilled rear and grooved fronts (for aesthetics)
Thats very true will they make then groove for the rears ?
Yeah to match the front
Ive just fitted the fronts Reyland discs , there excellent
Did you fit them to your existing bells or buy new from Reylands?
Been thinking of buying these as well. Did the mounting bolts come off the old bells easily enough as mine look quite rusty?. Also is there an additional noise from the grooves. My experience of grooved discs from years ago was that they tended to give off a whirring noise .
- Bladerider
Reyland ??
As in Martin Hadland ??
Yes
