2004 Audi RS6 Plus C5 Avant - South Africa
MeTsU
Re: 2004 Audi RS6 Plus C5 Avant - South Africa
Post by MeTsU » Tue Mar 20, 2018 3:12 pm
Shoppinit wrote:
Tue Mar 20, 2018 2:55 pm
What, no xenons?
Strange thing is, that it does have the Bi-Xenons. You can hear the shutter open and close when flashing the high beams.
2004 Audi RS6 Avant Plus #283
MeTsU
Post by MeTsU » Tue Mar 20, 2018 3:15 pm
I will have to see if I can find out the location of the unit as I know there's a few possible items related to that error code. I think this module is located (I believe) on the right frame rail behind the radiator from what I have read.
Post by Shoppinit » Tue Mar 20, 2018 3:19 pm
On LHD cars it's on the left chassis member. Don't know if they moved it for RHD cars. They do for some stuff, but not everything. I would gamble on it being on the left, but I have nothing concrete to base this on.
Post by Shoppinit » Tue Mar 20, 2018 3:20 pm
You should check the fuses and wiring first. And make sure the fan spins by hand.
MeTsU
Post by MeTsU » Tue Mar 20, 2018 3:23 pm
OK cool, I'll take a look tomorrow (Public Holiday in South Africa) and see if I can locate it. I will also chat to my Mum who is coming to visit us beginning of May. I might need to try purchase that controller from Ebay as a spare.
Yeah, I'll double check fuses but I didn't see any blown when I first got the RS. I also checked the fans and they seem to be free.
Post by Shoppinit » Tue Mar 20, 2018 3:29 pm
The fuses are hidden behind the dash (not the ones you access from the side of the dash). They are a PITA to check. You need to remove some trim to get to them.
MeTsU
Post by MeTsU » Tue Mar 20, 2018 3:33 pm
Oh.... I know about the relays back there. I've stripped some of the lower pieces of trim in the interior, I will try take a look there then too. I also need some lessons on how to use Elsawin properly. :oops:
Post by Shoppinit » Tue Mar 20, 2018 3:42 pm
Elsawin: It's like a well stocked library... with no lights, no windows and no filing system.
Post by Shoppinit » Tue Mar 20, 2018 3:47 pm
Left, in direction of travels, obvs.
MeTsU
Post by MeTsU » Wed Mar 28, 2018 4:32 am
Shoppinit wrote:You might be able to buy an A3 unit (much more common) and swap the facia. It'll be tricky sourcing an A6 RNS-E.
There was some discussion on this on here, but quite a while ago.
Hey Shoppinit, going back to this comment, were you refering to this thread?
viewtopic.php?f=2&t=101770
A mate sent me a link to a brand new A4's RNS-E front facia - looks identical I think, so that might be a possibility.
Although, I'm feeling that I might be better off just buying a later model RNS-E and adapting the facia (I'm sure the PCB below is identical, well I hope)...
Post by Shoppinit » Wed Mar 28, 2018 8:25 am
I don't think the A4 fascia will fit. It's closer than the A3, but IIRC it needs to be a A6 fascia for a perfect fit to the dash. I could be wrong.
That link looks familiar. I think after that thread I decided I would stick to the RNS-D. I only use it as an amplifier anyway and for that it's fine.
MeTsU
Post by MeTsU » Wed Mar 28, 2018 8:32 am
I'll have to see if I can get the seller to take some measurements for me. Worst case, it looks from the photos like I would be able to literally replace just the front fascia plastic from the metal backend (where the PCB is mounted to).
Only reason I am considering a "new" RNS-E is I'm not even sure if the rest of mine still works as it should. Plus the 4GB limitation of the mem. cards is a little saddening. I'll do the maths and have some chats and see what I can find out.
I'm an OEM/OEM+ type of guy.
Post by bam_bam » Wed Mar 28, 2018 12:34 pm
Elsawin: It's like a well-stocked library... with no lights, no windows and no filing system.
Brilliant.
*well-stocked
V!per
Post by V!per » Wed Mar 28, 2018 1:44 pm
A4 fascia Definitely doesn't fit - it's a bit narrower and a bit higher than the A6 one
MeTsU
Post by MeTsU » Wed Mar 28, 2018 2:08 pm
Ah, thanks for the clarification on that. So, now I need to figure out what to do. See if I can find a damaged RNS-E from an A6 where I can pull the PCB I need from, or, get a nice "new" working RNS-E (193G for eg) and transfer just the plastic fascia across to make it work in my RS.
Users browsing this forum: No registered users and 236 guests
