Just a quick one lads,
I am havibg my clutch done in couple of weeks but i am supplying the parts,
Is there anything else you guys think i should have changed whilst its been done?
So far the parts i have got together are...
Clutch friction disc
Clutch pressure plate
release bearing
Release bearing guide sleeve
New clutch fork
And the uprated clutch pipe from this forum.
Maybe slave cylinder?
Clutch parts
Clutch parts
Re: Clutch parts
How many miles has the car done?
Flywheel should be fine?
Re: Clutch parts
Yes mate flywheel is fine so i am leaving it for know prob change it all next time.
Re: Clutch parts
It's a big job mate as had mine done a couple of weeks ago, I would highly recommend changing the flywheel at the same time as it's all apart, bit more money but will save in the long run!
I went for the single mass conversion but you will need to supply the bolts with that, Euro car parts sell all clutch bits you need and if you time it right then you should get it all for a steal. Only thing the kit doesn't come with is the thrust bearing, you'll need to source that.
Re: Clutch parts
Ok cheers for that pal,
Today i had a phone call about the clutch i have brought, an rumour has it that sachs have had a few problems with there performance clutch kits? Breaking up/exploding!?
Has any heard anything at all about this?
Re: Clutch parts
Send it back and go for a JH Motorsports setup. Tried and tested to death
Users browsing this forum: No registered users and 126 guests
