Clutch parts
Lukes3
Clutch parts
Post by Lukes3 » Wed Feb 14, 2018 12:02 pm
Just a quick one lads,
I am havibg my clutch done in couple of weeks but i am supplying the parts,
Is there anything else you guys think i should have changed whilst its been done?
So far the parts i have got together are...
Clutch friction disc
Clutch pressure plate
release bearing
Release bearing guide sleeve
New clutch fork
And the uprated clutch pipe from this forum.
Maybe slave cylinder?
DavidRS4
Re: Clutch parts
Post by DavidRS4 » Wed Feb 14, 2018 12:36 pm
How many miles has the car done?
Flywheel should be fine?
Lukes3
Re: Clutch parts
Post by Lukes3 » Wed Feb 14, 2018 7:49 pm
Yes mate flywheel is fine so i am leaving it for know prob change it all next time.
Callumrobin
Re: Clutch parts
Post by Callumrobin » Thu Feb 15, 2018 2:12 pm
It's a big job mate as had mine done a couple of weeks ago, I would highly recommend changing the flywheel at the same time as it's all apart, bit more money but will save in the long run!
I went for the single mass conversion but you will need to supply the bolts with that, Euro car parts sell all clutch bits you need and if you time it right then you should get it all for a steal. Only thing the kit doesn't come with is the thrust bearing, you'll need to source that.
Lukes3
Re: Clutch parts
Post by Lukes3 » Thu Feb 15, 2018 11:08 pm
Ok cheers for that pal,
Today i had a phone call about the clutch i have brought, an rumour has it that sachs have had a few problems with there performance clutch kits? Breaking up/exploding!?
Has any heard anything at all about this?
DavidRS4
Re: Clutch parts
Post by DavidRS4 » Fri Feb 16, 2018 8:36 am
Send it back and go for a JH Motorsports setup. Tried and tested to death
Users browsing this forum: Majestic-12 [Bot] and 161 guests
