rs6 c5 how to do a boost leak test ?
jangoc5rs6
Post by jangoc5rs6 » Tue Jan 16, 2018 3:03 pm
hey guys new to the group ive had my rs6 for a month now and a friend has previously had one and recons mine is underpowered, recons I have a boost leak.
I have some experience with the b5 rs4 but not the rs6 any help would be appreciated. what pipe do I connect the tester to and what to block off please?
Re: rs6 c5 how to do a boost leak test ?
Post by Shoppinit » Tue Jan 16, 2018 5:33 pm
It'll be similar to the RS4. Plug one inlet, put a pressure gauge on the other one and inflate and see if it holds pressure.
If there's a boost leak it's likely to be the intercoolers. Do a visual inspection first. If they have a dark patch in the corner they are leaking. Or, even easier: if they are OE then they are leaking.
Could be hoses. Should be obvious if there is damage.
Have you got a Vagcom? You should log the boost you're requesting and achieving. That will give some pointers.
Mɐʇʇ
Post by Mɐʇʇ » Wed Jan 17, 2018 12:38 am
:thumbs:
Ben_r1
Post by Ben_r1 » Wed Jan 17, 2018 8:50 am
Some garages have boost leak testers now where they compress the system with a gas mixed with uv solvent and then use a uv light to identify the smallest of leaks.
Cost me £50 last time and took 20 minutes.
Gav66
Post by Gav66 » Wed Jan 17, 2018 1:38 pm
So am I right in saying that to do a boost check through Vagcom Its 3rd gear and rev to 6000rpm and log and results should give an indication where the leak is ?
I had mine checked at a garage and did show a boost leak but was supposed to go back for a smoke test but everytime I've phoned him he won't answer !!!
Can't seem to find anyone with a good RS6 mechanic locally.
Is it best to get a garage to test or try and find the leak myself with Vagcom?
Never done a test before .
Post by Shoppinit » Wed Jan 17, 2018 2:08 pm
Best to log boost and mafs when driving in different conditions. The car will never ask for boost with no load, i.e. In neutral. I'll try to post some logs up so you can see what I mean.
Steveo
Post by Steveo » Wed Jan 17, 2018 2:15 pm
[quote=Gav66 post_id=873407 time=1516192713 user_id=40102
[/quote]
What part of the country are you in?
RS6 C5, MTM
jangoc5rs6
Post by jangoc5rs6 » Wed Jan 17, 2018 3:00 pm
thanks guys will try that this weekend no don't have a Vagcom will do visuals inspectionsf first. if I cant find any is there any one near west Yorkshire that can test this for me ?
Gav66
Post by Gav66 » Wed Jan 17, 2018 3:07 pm
Steveo, I am in South West Scotland, Ayrshire.
Steveo
Post by Steveo » Wed Jan 17, 2018 3:20 pm
There has always been lots of RS's in Scotland, presumably because of the oil industry.
Put up a new post asking for recommendations for a decent mechanic near(ish) to you. There must be some
RS6 C5, MTM
Gav66
Post by Gav66 » Wed Jan 17, 2018 6:41 pm
Never thought of that Steveo, will do.
Cheers.
jangoc5rs6
Post by jangoc5rs6 » Thu Jan 18, 2018 10:18 am
[/qu
will do that thank you
madi
Post by madi » Fri Jan 19, 2018 6:57 pm
Im from Bradford if you need any help... Try Chris umpelby he so ok.
Users browsing this forum: Majestic-12 [Bot] and 163 guests
